Andre Visser said:
Are you suggesting that SQ only exist above 15Khz? Your comment shows your ignorance of what was said.
If anything was ever "silly" the logic behind your flow here is.
Andre please re-read you own post. You, not me, stated that wisdom could make up for "the lost few KHz at the top".
Just tell us how, once you can't hear it because it is "lost", you are going to use wisdom to judge that is is good/bad or anything else?
john curl said:This is silly, many experienced older people can still hear subtle listening differences. Apparently it isn't as much a part of extended listening response as many presume. It is also true that when we were younger we were often able to hear better. I used to hear to 24KHz myself, when I was about 20. Forty years ago, at AMPEX, I was asked to find a particular problem in another office, the mechanical engineering group. I heard this ultrasonic oscillation that seemed to be bouncing off the walls. I narrowed it down to a squeaky bearing in a tape recorder undergoing a life test. Most heard nothing at all, some heard something, but indistinctly.
Now, I can't pretend to do that today, but I had a serious audio test on my hearing done recently, and the doctor said that I was just fine for my age. To my surprise, the former mixing engineer for the Grateful Dead and one of the crew and I recently talked together at the AES. IF the presumptions that are made here were accurate, then if ANYBODY should need a hearing aid, it was these two! YET we conversed in a normal tone without electronic aids in a relatively noisy environment. Go figure.
John
I have also been touring as a sound engineer for several years (did my first gig in 1969) and to be honest I still hear a lot better than the average people do at the same age. That said I have also met sound engineers that has ruined their ears by bad sound.
Hearing damage has almost nothing to do about how loud the sound is as long as it done the right way.
Stinius
john curl said:One is an open loop design and the other is a high feedback design.
John,
Congratulations for the award! You definitely deserve it.
I'm glad for you.
Now, you stated earlier that the Blowtorch is only slightly better than JC-2, yet, JC-2 is a high feedback design.
So, is high feedback not that bad after all?
Or is it dependent on the entire circuit?
alansawyer said:If anything was ever "silly" the logic behind your flow here is.
OK, what I was trying to suggest was that one learn to listen to music, detail, ambiance, soundstage etc., when one become older your listening skills should be better even with the loss of a few Khz at the top. Hope it make more sence now.
Juergen Knoop said:
does a prototype exist at all?
regards
Not yet.
I still draw the PCB layout.
I had an eye operation last week and still peep at my puter's monitor with one eye only, so, it takes longer than usual. I believe it will take few weeks before I'll have a prototype (PCB and parts are to be shipped here from the USA).
This is in accord to my own experience.
Yes, congratulations John.
PS. There can't be much wrong with your hearing if you can hear cable differences.😉 😀
Sorry to say, but I agree.
Stinius
NFB
This thread has even more negative feedback.
john curl said:The JC-2 has lots of negative feedback. Less than a typical IC, however.
janneman said:Andre, my 2cents worth:
.....Summary: A great evening to enjoy, but soundwise, the CD is better.
Jan Didden
Thanks Jan, it is interesting to know.
I'm too scared to suggest that hi-fi can sound better than a live show. 😀 😀 😀
Re: NFB
Let’s differ between local feedback and global feedback.
Stinius
Edmond Stuart said:
This thread has even more negative feedback.![]()
Stinius
Joshua_G, please don't get ahead of yourself. Feedback is a problem, ESPECIALLY when a LOW open loop bandwidth is involved. Keep the open loop bandwidth fairly high, (above 1KHz at least) and feeback can make a 'good' sounding design, if not a 'great' sounding design. Measures better and hides a lot of open loop non-linearity, as well. All my Parasound designs are based on this formula. Vendetta and Blowtorch tend toward open loop.
I would try the regulator part with a dummy load first. Opamps don't have much output current. But it might damage the DAC, if it oscillates.Joshua_G said:Not yet.
regards
I can clearly hear it 😀 😀 😀
Jan Didden
cbdb said:Use your ears but like any test equipment know there limits.
know there limits.
that's known?
Thank you for the clue.
PMA said:I would suggest OLG corner at least 10kHz, preferably 40kHz or more.
Thank you.
It clarifies the situation further.
janneman said:I can clearly hear it 😀 😀 😀
Jan Didden
Yes but you didn't do an ABX test and we can't remember the music for more than 10sec anyway. Definately not valid! 😀 😀 😀
regards
Thank you.
It's obvious to me. I didn't dream to do it otherwise, since I'm well aware of the possibility of oscillations. Yet, a dummy load is not expected to behave like the actual load itself.
- John Curl's Blowtorch preamplifier
