John Curl's Blowtorch preamplifier part IV
Almost as bad as faking to not have an ... whatever
Are you referring to the original or the copy.
I think the copy is good value for money.
Silver plated ofc copper strands, each strand separately enclosed in a teflon tube, surrounded by a filament to keep a distance from the teflon tube and terminated with (fake ?) WBT connectors.
Worth to give it a try IMO.
Hans
RLC components of cable is simple. But microphonic (capacitance change because of vibration) and triboelectric (because of vibration) is difficult. Because vibration is not always happen. So, it was called dynamic distortion.
So where does this vibration that is enough to create audible effects come from? And surely it would be easy to remove it and then compare...
Floor vibration from speaker sound/bass mostly. Cables laying on the vibrating (typically wood) floor. Some people use cable "lifters" to reduce it.
You can also use a dielectric which is solid and not foamed. No loose wires in a semi-air core construction. Tightly wound shield. All construction which makes for a very tight and almost rigid cable.
Oh. And IMO.
[I have concrete floor, so no problem that way]
THx-RNMarsh
In my opinion, an amplifier should be reproduce consistent timbre and frequency response at any SPL (Sound Pressure Level).
What do you think?
Do you have experience if you listen in different SPL, the timbre and frequency response changed?
That's called Fletcher-Munson, unless you scale down the output for a constant SPL.
And don't forget the compression of the ears vs SPL; still AE101, but breaking out of the Bode plots gets you a bit further.
Parasound Debuts Flagship Halo JC 1+ 450-Watt Monoblock Power Amplifier | The Absolute Sound
:cheers:At 83 pounds, the new JC 1+ is 30 percent heavier than the JC 1. Its new power transformer has 20 percent higher capacity, while additional Nichicon power-supply filter capacitors increase from 132,000 uF to 198,000 uF. The new amp boasts 24 Sanken 15A/230V output transistors compared to 18 — a 33 percent peak current increase, for music that truly soars.
The Parasound Halo JC 1+ is remarkably quiet and is thefirst commercially built product to employ active high-frequency noise filtering with Bybee Music Rails™, eliminating input stage noise that compromises sound quality. Curl’s newly-designed driver stage employs a cascode circuit with greater open-loop bandwidth and increased linearity. In another first for the JC 1+, the input and driver stages reside on FR-408 printed circuit board material. Until now FR408 was used in super-computer and aerospace applications. The input-stage power supply is totally independent from the main power supply. Its R-core transformer isolates sensitive circuitry from high-frequency power line noise. This input stage power supply employs quiet high speed/soft recovery diodes and 22,400 uF filter capacitance, to deliver +/- 112 VDC rail voltage, virtually eliminating distortion. Premium Wilson Audio REL capacitors use a proprietary design, which resists micro vibrations that typically degrade the sound quality of other caps. The addition of an XLR Loop Out as well as a 12V-trigger/delayed-turn-on improve the connectivity and utility when multiple JC 1+s are used in bi, tri, and quad amp configurations.
If the floor is vibrating you are already screwed.
yep. Lots of houses/apartments have wood floors. Plywood over spaced supports is common.
I had a new 3 story house being built near Sacramento, Calif, USA by the River and they spec'ed plywood floor and wall-to-wall carpet over it. I wanted tile floor. it was a $40K upgrade to the house to stiffen and make the floor so it would not flex or the tile would crack.
This is typical of housing construction today. They do vibrate.
THx-RNMarsh
No I am not. Thats Waly's spin.
It doesn’t seem that way to me
Same goes for unmasked copper PCB traces creating surface diode. Which would affect the higher freq at surface (skin effect) the most . A reason to gold plate and/or mask/seal coat/insulate it from oxidation affects.
Please if possible provide a link
It was shown that it is not imagination or bezar theory. It is real and measurable of significant level.
George
Oh. And IMO.
THx-RNMarsh
Most people have carpets too? And if you have a bare wood floor as Scott says you have bigger reflection issues...
But the real point was - sufficient vibration to be audible -- how much is that, regardless of floor type?
Even with a lot of bass, a line level cable isn't long or big, it's a small target for those basson particles...
WOW but I need 4 of them Only $34,000 USD :-(
Oh well.
Meanwhile, We found the thermal tracking of the OPS bias was not tracking. New pcb layout and more OP devices, too. 🙂 That should do it. Units are at Asean show now. Heard it sounds great but have to wait until after show to get them back. Oh and upped the bias to total of 100W class A. Bias/temp is stable.
:xfingers:
THx-RNMarsh
:cop:
Another clean-up of posts containing personal attacks and divisive attempts plus collateral.
Argue over the technical subject, do not turn personal (expressed or implied). Again, mind Forum Rules 1, 2, 3
diyAudio Rules
This is the last of innocuous cleaning ups. Next round will have penalties.
You have been warned.
George
