John Curl's Blowtorch preamplifier part IV
I spoke to Jack Bybee this morning. He is still working on new discoveries. One is going into a power cord that his (and my) associate Mike, (who holds more degrees in both physics and engineering than most of you here) is producing.
:yikes:
The original snake oil was oil extracted from sea snakes as a chinese medecine for people, usually rich in mono-unsaturates. Later in the USA and in the 1800's it was taken to mean oil from snake river, which was a crude oil leakage, all the lighter fractions boil off, so it was natural gasoline/tar blend oozing into the river that was scooped up by travelling medecine men to be sold at fairs, but the original would have been of some help for mild arthritis etc.
RLC components of cable is simple. But microphonic (capacitance change because of vibration) and triboelectric (because of vibration) is difficult. Because vibration is not always happen. So, it was called dynamic distortion.
Like temperature change, temperature modulation because of signal, temperature feedback are also difficult to see the effect. It is dynamic distortion.
Static distortion measurement using sine wave is sooooooo.... easy.
Is the distortion audible? No. It is below your hearing threshold. You need low-fi equipment. 😛 😀
Just get to the bottom of this. Are you saying that skin effect is an audible factor in audio electronics? If so, where are the demonstrated cases?
Any links?
No I am not. Thats Waly's spin. i am talking about copper oxide forming a diode layer... also at surface.
It was shown that it is not imagination or bezar theory. It is real and measurable of significant level.
It CAN be a source of distortion in oxidized cables/conductors/paths/contacts.
-RNM
... The QSE affects the polarity of all electrons and protons within it’s magnetic field, affecting their oscillation by making them more aligned with each other...
You should try it before condemning it, Hans. I have his latest stuff in my audio system, and they work!
It seems JC has confirmed that positrons and anti protons are produced by the QSE. Truly astonishing.
