John Curl's Blowtorch preamplifier part IV
We seem to have a wealth of listening experts here but a dearth of hearing experts.
One thing I didn’t see in that article you referenced but have read in other research, is that the ossicles seperate when exposed to loud noise for long periods. This is to protect the inner ear, maybe some do that better than others?
And if the hair growing out of my ears are any indication of cochlear hair re-growth I’m all good! 😛
Thank you George.
Note in the first article he provides analysis on dispacement related distortion, up to 25% capacitance imbalance, distortion is still low.
Sorry, IPad battery died..
The distortion analysis is good, but does not address the issue of current difference in the stator loops. As I pointed out, even a direct short to the stator will result in currents in the low nano amp range. The part per billion aspect of a two layer coat still holds no matter where the diaphragm is.
Earlier I stated "3D problem viewed as 1D". That was not a slight, it was a statement of the type of analysis being done. Simply viewing an estat as a position and time varying capacitor is one dimensional. Segmentation of the stator and driving it like a phased array turns it into a 3D problem.
1: the delay from ring to ring is electrically derived. Was it derived based only on speed of sound principles, or was the shear wave velocity of the stretched membrane considered?(ohm Walsh).
2: is membrane tension optimized for shear wave velocity, and are the edges supported by a feature which reflects the wave or absorbs it?
3: given the phased array drive, the e field the diaphram sees is no longer normal to the surface. Given that, now the charge transport velocity across the film comes into play. I've seen no discussion of that.
4: now that the e field is no longer normal to the surface, the relationship between the bias voltage and the stator voltage will have an impact on the lateral forces the charge on the film will see. A simple 1D analysis does not consider that.
It is that reason I asked previously if anybody has done polar plots vs bias voltage.
Oh, and the attempted slight against me, to stop trying to play Einstein? Nothing can be further from the truth. All I have done is provide a bog simple engineering analysis. So simple, that I didn't even have to take my shoes off to count past ten.
Jn
Streng published results wrt charge movement on the membrane:
J.H. Streng; Charge Movement on the Stretched Membrane in a Circular Electrostatic Push-Pull Loudspeaker; JAES, Vol.38, No.5, 1990 May, 331
Harmonic distortion (at steady state excitation 😉 ) contribution negligible in a propperly designed speaker, linear distortion in the low frequency band is more severe.
It's available:
(PDF) Charge movements on the stretched membrane in a circular electrostatic push-pull loudspeaker
It's available:
Excellent, excellent...thank you..that is a great paper.
While he did not pursue the analysis of bias voltage sensitivity directly, his very last sentence pretty much says it all..
If linear operation of the speaker is desired, then additional measures will have to be taken to insure that the amount of charge on the membrane remains constant, especially in the case of large membrane deflections.
Nice, very nice..again, thank you.
john
No sense in keeping all of that golden ear goodness to myself! 😀
You may want to do something about the fur first, there are specialist tools for the job
Jn
The tension is, with a safety margin, enough to counteract the electrical negative compliance. In esl57 and 63 at least no special feature for absobsion of reflections. The membrane is light enough for air load to dominate might mitigate reflexions a bit perhaps.
/örjan
