Yes, there's more to it than just basic physics.
From a slightly different angle, one of my favorite demo for smaller speakers is to listen to them as is, then have someone lift them up lightly, by a cm or so.
You could sit on a pillow or is that different. What is not basic physics about lifting an object a cm? There is the relativistic issue that the age of the speakers changes a few atto-seconds or would that be zepto? Does it mean that if your wife changes shoes your stuff sounds bad again from the kitchen/garage.
BTW thanks, I never bothered to see if Focusrite updated the driver for the 2i2, I just put it aside and used something else. I works seamlessly again now.
Such room is not an example of proper acoustic treatment. Person who did that needs to study up on room acoustics.Yeah closed heavily damped listening rooms are more like theaterettes......fine enough for tv/video but too dead f and too isolatedor good sound.
What I don't get is how speakers can be optimised for bass and everything else without being in different places, room modes are real. But I get your/their message LOUD AND CLEAR 😎Okay........................
The Mantra of Master Set, Sumiko Method, Rational Speaker Set Up, whatever is...........................
ANY SPEAKER ANY ROOM
I think it is due to the multiple eigentones of the room.
Does this mean there will be no more debate about how DAC performance difference in the inaudible range to the nth degree because there are bigger issues to deal with as billshurv puts it?Yes, there's more to it than just basic physics.
From a slightly different angle, one of my favorite demo for smaller speakers is to listen to them as is, then have someone lift them up lightly, by a cm or so. The difference is not subtle, and brings up all the discussions about speaker stands, spikes, and so forth.
At the end of the day if we have a system/room that does vary widely over a few inches then arguing the last gnats chuff of anything is pointless. There are bigger issues to fix there.
... What is not basic physics about lifting an object a cm? ...
Think vibration: lifting a speaker even a mm from whatever support it used to sit on will change the way the cabinet vibrates, for better or for worse. Like stvnharr said, try it yourself, it takes only a minute.
Btw, you're very welcome. 🙂
If a too heavily treated room is bad for sound, what about listening on a rooftop with no walls or ceiling? How do you make that sound good?
I am now running my Tascam soundcard loopback Line Out to Insert In with standard bootlace elcheapo 2RCA-2RCA cable.
How do these numbers stack up ?.
Dan.
View attachment RightMark Audio Analyzer test_ comparison.pdf
Dan.
I haven't been on a roof top, but when outside with nearly no barriers (all really far away), I used some OB speakers for a eulogy and after party thing. The sound was AMAZING. If you've never done this, you've never really heard Frank sing.
I have, didn't do anything certainly not dramatic. I could try again, I don't listen very loud usually. BTW why does everyone always end up saying all these effects are "dramatic". My idea of dramatic is to swap out Klein horns for Magnepans without changing anything else. Also this is still ordinary physics.
That wouldn't be called "room acoustics".what about listening on a rooftop with no walls or ceiling?
Perhaps you can look up how they did it.How do you make that sound good?
Best way to try this is to have someone stand behind the speaker and lift it while you sit back and listen; the diff is the way the cabinet walls are damped, or not. Feel free to close yours eyes if you like it blind.
And of course everybody uses superlatives to get people's attention. 🙂
Drap a thick Moving Blanket over the speaker to absorb sound from cabinet sides and back. Cheap experiment to see if your cabinet is producing perceptible sound or not.
Blue Moving Blankets - Blue Moving Pads for Moving, Packing & Storage
THx-RNMarsh
THx-RNMarsh
My custom DIY-built high SR, Ultra low distortion SOTA CFA power amps. Finally got the LED lights working well (blue). The row of LEd lights had been uneven in light output. A new source of LED which are very consistent was suggested to me by friend, Jam.... of Pass Labs.
All chassis parts are CNC milled.
THx- RNMarsh
THx- RNMarsh
Forget about my term "inter-speaker distortion", just watch this video. It explains everything much better than I can.
YouTube
Good grief. That's over an hour long. The process should need only a few mins to describe, or a simple flowchart - where in the hour of waffle is the meat??
THx- RNMarsh
Very nice Richard.
And a big salute to Dadod as well who has certainly moved the performance needle with his design. Superb!!
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part III
