If you change all the rubber parts (orings, dampers, hoses etc) and service everything in time, don't you think a good big modern car can live a lot longer. The only annoying thing will be the furniture noise that inevitably appears, and the interior that gets worn.10 years max. Major gum up, thicken, oxidize. Basically, stop the clock. Synthetics, the claim is that they don't oxidize up. Give me 20 years, I'll get back to you.
I just restored an old Volvo S70 from 1998 and it's almost like new. 200 000 km, I expect 300 000.
I find the foam used to pad things wears out a bit before disintegrating. A Buick of mine had the ceiling foam fail and the fabric kind of looped down.
Many manufacturers pretty much want nothing to fail during the warranty period, but after that....
I did have one dealer put battery acid in my power steering pump, I had the car 3 years and just under 200,000 miles. The abrupt change in steering feel and the color change gave it away. Drained and refilled a bit of a bother, but it worked adequately after that till it got replaced at 264,000 miles.
I remember, molybdenum disulfide was expelled from being used in aviation lubrication grease due to hydrophilic action. Water entrapment led to localized crevice corrosion, leading to deep pitting
There must be some 20 years since then, I found a discarded molykote black grease paste in my moto tool box lately.
Crevice corrosion [SubsTech]
George
George, many thanks for the reminder and link!
The base stock of oil and for gasoline is the same for every brand. The difference is in the brands Additives.
-RNM
-RNM
Classical. Too in mine.I find the foam used to pad things wears out a bit before disintegrating. A Buick of mine had the ceiling foam fail and the fabric kind of looped down.
Voluntary sabotage?I did have one dealer put battery acid in my power steering pump,
-RNM
The so called Pennsylvania grade crude oil is different than the Asphaltic crude normally used. Until recently the oil was preferred as the PA stuff congealed to waxy residue as opposed to the others tar like gunk.
Voluntary sabotage?
They haven't sold me a car since then. Pretty hard mistake to make.
Long ago VW had the windshield wiper fluid container easy to confuse with IFR the brake fluid or was it the radiator? Not a good design.
-RNM
Richard,
This is not the case, if you are so interested, please read my TechBrief at:
https://zddplus.com/wp-content/uploads/2017/05/TechBrief10-Oil-Base-Stocks.pdf
I am a card carrying member of the STLE (Society of Tribologists and Lubrication Engineers) and have designed lubricants and additives for several purposes as well as having traveled giving seminars on ICE lubrication.
Cheers!
Howi
Howie@ what other hidden skills do you have?
When I worked on satellites that always seemed to be a tribologists dream/nighmare. And a machinists nightmare as they were hogging out solid lumps of Be for the solar array bearings.
Howie@ what other hidden skills do you have?...
I majored in both CE and EE in college, atomic attraction and tribology have always been an interest of mine as well. It is fascinating how adhesives and paints adhere or don't, and conversely how so many different forms of lubrication work or don't. The subject is not entirely as simple as one may think. A great book on this subject is 'Molecular Adhesion and it's Applications" by Kendall...
Howie
You have just become my new best friend...😉Richard,
Cheers!
Howi
I will eventually be pinging you for information regarding horology lubricants.
John
I understand my youngest daughter went to a summer camp where we had to buy a full dressage tack for her.
I hear you, I live on a hobby horse farm and just the maintenance overhead threatens to be all consuming: broken fence posts and wires, fence charger repair, bush hogging, manure spreading, tractor maintenance, outdoor water system maintenance, barn repairs and the list goes on...fortunately my wife is a vet so horse and tack care is her job...
Cars are much lower maintenance and can be turned off and parked.
Howie
Reminds me of a scene from Annie Hall. 😉 I once was at a wine tasting and a guy across the table made a comment about the correct way to freeze and thaw fish and I disagreed with him. It turned out he was a PhD physicist specializing in cryogenics and a consultant to the Navy Department on preparing sailors mess.
I spent 5 years studying grease at my last job. I learned that I don't know anything about grease, after the 5 years.
There is so much information, the specifics for each application are different, etc etc,
No wonder people spend entire careers studying lubrication.
I found it to be fascinating.
It's totally subjective but what billshurv said above makes total sense to me: boosting/cutting certain frequency range can create an illusion of different height. And the speaker's impedance vs frequency will change the amp's frequency response to some extend, and provoke that illusion under certain circumstances.
Yes mostly in tube amps, so you like the distorted soundfield created by amplifier short falls.
SS amps too are sensitive to load, e.g. an expensive one here.
Of course, adding a ton of GFB will fix this, while creating other problems. Again, this is not the whole truth, so don't blindfold yourself.
I spent 5 years studying grease at my last job. I learned that I don't know anything about grease, after the 5 years...
I deeply love this.
You can easily substitute "grease" by anything you fancy, or simply: "The more I learn, the less I know".
PS.: just to make sure: this is a praise!
And others insist on distorted soundfield created by transducer short falls. It's called hifi.... you like the distorted soundfield created by amplifier short falls.
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part III
