... And I don't know that the noise is low between the SG. But my experience with picking up cheap transports from thrift stores is that drives begin getting errors. They all tend to have a terminal illness and you start getting audible bit loss after awhile because they just don't last. Where as I had an Arcam CD player that was much older and lasted longer than any of the DVD players I grabbed.
I second that. Having modified a whole range of CD and ROM transports for CD Analysis duty by buffering the raw EFM signal for external use, there is a huge difference between the performance and reliability of say a Lite-On $20 drive and a $150 Pioneer drive. Performance issues are not necessarily related to recovering the data successfully; many cheap (and other) transports then contaminate the digital output with noise from the tracking and focus servos. This noise can cause decoding errors and BLER, or in worst cases E32s. And reliability comes with build quality, many cheap transports are manufactured with loose tolerance molded plastic parts and can deliver a higher BLER than one more stoutly constructed.
At WXYC we use cheap Sony players in the listening stations and merely replace them when they get tired, usually a few per year. In our Control Room where the CD players are used 24/365 we use Tascam Pro players and I refresh (replace) the full transport usually once a year. The cheap Sonys last a month or more in that service.
Cheers!
Howie
What is Oppo ? A smartphone ? A blue ray player ?Speaking of OPPO
A hell of an expensive transport. See What is an audiophile CD player? for measurements on a 10 quid salvaged Sony DVD player. Bottom line, practically at the theoretical limit of the CD recording standard. The transport does not impact at all the digital output.
Also see Matrix HiFi --> Blind testing high end full equipments for a fair (but not perfect) subjective comparison.
I would throw it in the garbage can if it didnt cost so much to do so. And, it was not played much. I was also trying the fibre optic output to the DAC. Same results. Sounds like low rez. So something is seriously messed up with it.
If only analog, I could fix it... removing electrolytic caps. But the FO port? Now what? Now I went back to reading the fine print.... high rez is only available on the HDMI port. Oh great!
Who makes a new cheap but reasonably accurate CD player? Newest players are not so hot either and we are down to one mfr of the drives.
Oh. I still have a ALESIS CD Mastering record/play unit. Guess I'll press that into service when I want to play a CD.
Best thing to do now is to copy all my tunes into music server files.
-RM
Now if we could only cure cancer.
THx-RNMarsh
They have. It is just not cost effective.
For all I care, at 10 quid, I could afford another second hand Sony transport every week. At an at least 1:100 price ratio, you do the math what's the better deal.
Of course, a potential customer would always be pushed to consider the prestige of a brand name over any technical reasoning and/or economics. This is is how the "high end audio" priests are surviving today, without that philosophy they would for long bite the dust. Nevertheless, they will, it's only a matter of time.
I have also had my fair share of going to thrift stores. It gets old and takes all day to find something if at all, sometimes. No thanks. If I go in one once awhile now I often walk out with nothing, and that is it for awhile.
-RM
except that uses the $20 Liteon drive Howie was talking about. Oh well.
Cheers
Alan
Oh pray do tell. I'll quit my job and find something better to do.
xkcd: Cells
What can I say? Cheap transports often have high error rates when new, never mind after some run time. You want good sound, you have to start with a decent transport. The best indicator to performance is to look at the eye pattern. That typically tells the whole story.
-Chris
-Chris
and you managed to find an xkcd I'd missed! Thanks!! 🙂
-Chris
Does anyone actually use the CD medium anymore? Even cars don't have drives anymore.
Hi Scott,
I do. I guess the last drives you will find will be in truck stops right beside the 8-track players, CB radios and cassette players.
-Chris
-Chris
Hi Scott,
I've been through them all and never did 8-track or CB, but I remember the CB nonsense, people trading handles in the hallway helping each other avoid smoky, building illegal PA's.
Hi Scott,
Same here, except I did have a CB. Missed most of the silly stuff and lost interest after Smokey & the Bandit came out.
I still have some really good car CD players and cassette decks (Nakamichi TD-700) i have a Concord and a Marantz around here somewhere too.
That was when I worked at Rat Shack in the 70's while I was going to high school.
-Chris
-Chris
What can I say? Cheap transports often have high error rates when new, never mind after some run time. You want good sound, you have to start with a decent transport. The best indicator to performance is to look at the eye pattern. That typically tells the whole story.-Chris
Bingo. And check it for stability with different discs and at multiple radii. I use this Leader EFM Jitter Analyzer to quantify transports:
https://proaudioeng.com/wp-content/uploads/2018/06/Leader-LE1852.jpg
In the optical disc world, all errors are due to jitter when you get right down to it...a bit of debris represents a really long "T" to the EFM decoder...
Howie
Hi Howie,
I used to use a Leader Jitter meter. I don't quantify it these days. I just know what's bad and ty to make it the best it can be. I do miss that meter occasionally. I can't justify buying another unless it goes cheaply.
-Chris
Edit: Yes, that looks like it
-Chris
Hi Howie,
I just found one of those on Ebay for about $80 US. I wonder, should I buy it?
-Chris
-Chris
Hi Howie,
-Chris
Can you watch the jitter as you listen?😀
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part III
