Hint low frequencies can mask higher frequencies.
True, and people can learn to overcome the masking. In music listening there is also a tendency to notice the highest frequency present, with intermediate chordal frequencies being masked. Music majors that have to take a course in transcription of live orchestral performances find it very difficult at first, but eventually they develop skill at overcoming the masking and are able to transcribe intermediate pitched instruments in even in rather dense orchestration.
But nothing by JC?
JC1 has been discontinued. Hopefully its replacement will be in the 2020 list.
The CD example only makes clear than one particular effect has been demonstrated and accepted as non-controversial. Doesn't prove anything beyond what it says. It does illustrate at least one kind of correlated high order distortion can be audible at low levels.
I see no protocols or detailed repeatable process laid out to verify any claims of audibility. I don't mean to be contentious but I spent weeks when selling amplifiers to the major cell phone manufacturers listening to reference designs and frankly never heard anything except different earbuds/headphones.
Ah the confusion and lack of common ground.
If you have THD in an amplifier must you also have IMD? Does the same hold true for a loudspeaker driver?
It would be difficult not to. I doubt you could come up with any weakly non-linear system that does not behave as expected.
In general I see your point, but please don't group any single individual, I'm like Groucho Marx in that "...I don’t care to belong to any club that will have me as a member."
Cheers!
Howie
I don't do exceptions as rules. That's for feminist.
If it makes you feel any better, I don't think about you ever, unless I'm reading your posts.
Bonsai, I read your paper and I don't necessarily agree with you. You have made many assumptions, including the definitions of TIM and SID. I know better since I worked with both parties on this issue back in the 1970's. You don't know as much as you think you do.
John, sorry but you live in the past.
Yes, every week the same stuff from 1970 all over again.
Ha ha. Classic JC.
You do know this 2019 and not 1970?
That makes it a day for this one then:
YouTube
https://files.diyaudio.com/forums/images/icons/icon10.gif
Well, I worked personally with Matti Otala at his lab in Finland, and also later at Harmon Kardon. I even co-authored a paper with him. I think that I know what Matti Otala thought TIM was, and it wasn't slew rate limiting.
I have personally known Walt Jung since 1974. He wanted me to work with him on SID, but Matti had contacted me first. Later, I got both Walt Jung and Matti Otala together at an AES to agree that SID is TIM. So there!
And in 2019 DC to daylight amplifier bandwidth is available off the shelf.
Yep, a coworker built a DIY active oscilloscope probe with around 500 MHz bandwidth from a few op-amps. I think ADA4817 and OPA659 or something similar. Obviously not for audio, but the point remains.
OK so what version is correct? Slew Induced Distortion is in fact the same as the un-needed newly named TIM, and was noted in 1958 as that paper showed.
Further, I was reading a review of the latest greatest dac yet at ASR and the guy that does the measurements said the dac distortion came at around -130dB, IIRC, and since the limit of audibility is -116dB the dac distortion is therefore inaudible.
Needless to say I was surprised at the number -116dB, not -117dB and not -115dB, but exactly -116dB! None of the other objectivist guys jumped in to complain either.
Did you ask where the 116dB figure came from? Perhaps it makes sense, perhaps not. It's an open forum though, you can ask.
For me that's not so important, I don't doubt that -130dB is well below the threshold of hearing, certainly I've never seen anything to make me doubt that.
But, if there's any decent evidence, happy to be convinced.
I have no idea where that number came from, but it sounds a bit extreme to me.
How many devices have input switches and volume controls that don't have -116 dB of "offness"?
This reminds me of an incident that happened at Harmon Kardon about 40 years ago. I was at a tech meeting with several engineers and managers, including Matti Otala. Well this on 'engineer' got up and tried to tell us what TIM was. Now, Matti and I did a paper together on TIM, and Matti invented the term, TIM, so this was almost laughable. Well, I interrupted this guy, to keep him from making a fool out of himself, and he got real mad at me, and threatened physical violence. He is long gone from the scene.
Invented is the correct term, are you going to kick sand in my face?
> appart a question of phase at HF ?
That and the fact that speaker back emf artifacts get fed back to the amp input .
As oppossed to going where ? Yes they get fed back to the NEGATIVE input and then the amp corrects for it. Learn some control theory.
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part III
