John Curl's Blowtorch preamplifier part III
This crock is resurrected every few years. Must be a problem with a short attention span.
I have rebuild your straw man experiment with this wantonly bad amplifier 9 years ago and I have proven that all frequencies that are created are intermodulation, and I even gave the order of the IM.
You used an op amp that was outdated even at the time of your original report, it was sandbagged with low operating voltage and a ridiculous input stimulus. And i also showed that a 25 year old LT1028 had no problems even with that abuse.
This is plain to see for everyone at < John Curl's Blowtorch preamplifier part II >
Gerhard
Gerhard, I am now talking here as to WHY we designed the test with a bandwidth limited SQ wave, and then ADDED an unrelated test tone. IF you read the first 2 pages that were written by Dr. Otala, not me, then you might learn something and save yourself from embarrassment later. Scott is concerned about something else entirely, and that is still up for contention.
For the record, I measured the best FET input IC op amp available at the time, the LF356 (in 1976) and published it in my IEEE article in 1978. Look at graph 1.
At risk of disgusting Scott, those old SAAB turbos can be tweaked to suicidal levels (400HP, front wheel drive, bring it on 🙂 ).
Thats what so nice about super chargers and turbo for power increases. Dont have to change cams and compression ratio's etc internally. With turbo's just reset the waste gate to higher level and A/F is automatically adjusted via fb from sensor. How cool is that?
THx-RNMarsh
