Thanks Bimo for the link to the audiosciencereview website. I joined! For some time I, like T, and several others, have found that debate here is not very productive, but I still like the links that many of you put forth. Personally, I am still designing amps and preamps, and I have to follow the design rules that I sometimes find challenging, that I have latched on to over the years.
As far as a line cord for the CTC Blowtorch: We (Bob Crump in particular) made custom AC cords for each Blowtorch. I never did an A-B test, but I use his cords, with a Bybee powerline conditioner.
I did try to eliminate any AC interaction, but I am pretty sure that improvements could still be made with improvement of the AC, especially less RFI input on the AC line.
Careful John, it's a den of objectivists there. Arny K, SY, Ethan Winer etc are all there. And they actually measure equipement and discuss measurements.
Very much so... and not all of them are so good at measuring.
I especially liked the power cable thread. Page 28, they're explaining how the copper lattice changes when exposed to very cold, gosh, minus 200 degrees. and, how the colder the better, holy mackerel, even liquid nitrogen!!!Careful John, it's a den of objectivists there. Arny K, SY, Ethan Winer etc are all there. And they actually measure equipement and discuss measurements.
Gosh.
We should find somebody with say, 25 years experience testing things to very high accuracies in liquid helium and liquid nitrogen, and explain to him all about this stuff, as they've clearly missed this.
Course, the guy who had Romex cryoed should probably pull the wire out of service and replace it with new that hasn't had the insulation compromised. Bog standard pvc does not handle LN2 temperature well, I've no idea what cryo treated cable minimum bend radius becomes, NEC does not have a table for stupidity.
Jn
Things to note about the study:
1. Did I understand that it's 4x 40db gain inverting opamps with padding? Perhaps useful to gain up the distortion products but is that a relevant use case? Maybe in mixing consoles. Rest of us aren't running 4x riaa preamps.
2. That's very close to a null result if I'm looking at it honestly. There needs to be asked how likely it is to have a consistent preference across a sequence of 20 comparisons. Does that distribution of trials end up looking like random variation? Even if not random, it's pretty small effect.
If you join the test, may be you say all op-amp sound same
Been a member there maybe 10 years. I found the science and theory to be reasonably decent, but nothing to write home about. For high level discussion, it was kind of lacking firepower. So, haven't posted there in perhaps five years or so. (Numbers may be off a tad, but not by much).Thanks Bimo for the link to the audiosciencereview website. I joined! For some time I, like T, and several others, have found that debate here is not very productive, but I still like the links that many of you put forth.
Following bimo's link, I do not see much of a change. Trying to be all technical like, but not floating my boat. Cryo conditioning stuff..sheesh, lumping electron conduction in with engine block and firearm steel treatment below the martensite finish temperature.. Makes me want to stuff his face into an actual metallurgical textbook. Read something darn it!!
Jn
That is what I like to do. But measuring without it leading to audible improvement seems to miss the point. And with SY and others, you cant tell if anything really makes an audible difference to them without each change going thru a rigorous DBLT. So, 'in the end' it amounts to very little gain in achieving a more accurate system and we are left with what we have now.
So, learning to both listen critically and measuring seems to be the reasonable and practical thing to do. Sure you might fail often but the successes are worth it IMHO. Failure is reduced by listening in the near field and by experience.
THx-RNMarsh
The above mentioned have never presented personal subjective appraisals of audio equipment AFAIR.
Siegfried Linkwitz did give subjective opinions but I have never seen calls to him to prove his findings/opinions by DBLT.
Dan.
THx-RNMarsh
See for me I see this Review and Measurements of Benchmark DAC3 | Audio Science Review (ASR) Forum as a good review. Data and no flowery bull on veils being lifted. YMMV
Very nice After the Fact review. Question the significance of the sidebands. However none of this is of any help to a designer. Or a DIY'er who wants to improve his/her designs.
I know both companies also listen in their selections of analog opamps et al as well.
THx-RNMarsh
THx-RNMarsh
Been a member there maybe 10 years. <snip>
Jn
Do you confuse two forums?
Afair the audiosciencereview.com forum was established in 2016....
The sidebands in DAC-3 are only seen with USB input, not with SPDIF. The Stereophile measurements were more thorough in that respect. Doesn't bother me I normally use SPDIF. But it does look like a problem was missed in the design.
Any ideas ?.The sidebands in DAC-3 are only seen with USB input, not with SPDIF. The Stereophile measurements were more thorough in that respect. Doesn't bother me I normally use SPDIF. But it does look like a problem was missed in the design.
Dan.
It is very possible. Amir was the major domo for the forum I was a member of. Did they change the name, or did the old one die, or does he have two?
I noted that some of the members on the ASR forum are the same monikers I recall from back then. So yah, could be me in a state of confusion...a very familiar place for me..
jn
Any ideas ?.
USB uses a !kHz frame rate. It is a known source of 1kHz noise.
And the test signal is also 1kHz.....uh huh.USB uses a !kHz frame rate. It is a known source of 1kHz noise.
Dan.
What is also of interest is how the masking may change as a result of much higher amplitudes. 100 dB? When I'm listening to Zep, or Cheryl Lynn, or even Bruno Mars, the only time I reach 100 dB spl is just before I put the needle in the groove...
I suspect that as the inner ear muscles contract due to high amplitudes, the masking curves may also change. I would expect the transfer function to the cochlea is altered as a result of changing spring constants.
Course at my age, the muscles have gone south for the winter..
Jn
Good news!
That muscle issue can be fixed.
Dan.
USB 2 for audio usually is 4 KHz. Still many, even very cheap, DAC's don't have those issues with USB. I would be looking at an issue in its internal sample rate conversion stuff. The whole point about async USB audio is that there are no clock issues from multiple clocks.
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part III
