Settling time will be that of the filters used, and independent of sampling per se.
Finally, a grain of sanity in this thread; exactly what I said myself in https://www.diyaudio.com/forums/the...wtorch-preamplifier-iii-3404.html#post6032210. But then of course, everybody talks, nobody is listening here.
ps. you have some noise above 80 kHz, what's that?
Probably electronic noise of some kind. Mic CMC 6 body electronics are supposed to start rolling off at 26kHz. Didn't use any power conditioner at all, and some of the equipment ran on SMPS including the RME ADC.
Most likely noise shaped dither.
No bit-depth reduction was used by me, could be some dither used internally in the ADC.
Jn, you keep talking in your posts about sampling at 44.1 kHz. The fact is that nobody does it that way these days.My point was, to sample at 44.1 required bricking the analog prior to sampling. Comparison of a 20k mic and a 40k mic both fed into a 44.1 system is not very useful. Comparing both fed into a higher rate system is useful.
Jn
Since the early '90s about 99% of audio A/D converters on the market are delta-sigma types with their front ends running in 2.5-6 MHz range. The final output gets decimated down/low pass filtered by built-in digital filters, so no matter what the output rate (44.1; 96; 192 or even DSD) the front part, including "gentle" band limiting filter, is always the same. And, there are no brick wall filters in front of A/D chips anymore. 😉
Studer did it. Ampex probably too.Has anyone ever looked at transient response of a tape system for ringing etc?
I've stared at enough noise shaped dither spectra.
From the standpoint of system response that really doesn't matter - the same function must occur before decimation. LPFs are also used in DAWs after many/all internal operations, to remove illegal values.
My complaint with this whole discussion is that it seems to try to cheat on the subject of illegal values. As if: "but what if I want to allow these illegal values".
All good fortune,
Chris
My memory must falter, could you please remind me where I promised you anything? Link please.
Otherwise, pleased don't play dumb, you know very well that the Oohashi paper is a total (fortunately, isolated) failure, quoted only by those with a vested interest in propagating audio grade FUD. The shortcomings were discussed in each and every audio related forums you mentioned it, and you ended up in the trash bin without exception, only to start over again the next chance you got. Do you need quotes/links? Athough you were quoted this analysis ad nauseum, here's again for others to go through: Audio Myths | PS Audio How do you qualify using IM marred speakers to play ultrasonic sounds, knowing that the IM products would fall straight in the audio band? And that later a corrected experiment by Ashihara completely debunked the Oohashi results? I still want to believe this was an honest mistake by Oohashi, due the lack of knowledge regarding sound reproduction.
And yes, it's the picky (when it comes to sensory testing) you which is supporting this failed study and conclusions by Oohashi. I'm afraid this does not qualify as a honest mistake.
In the psaudio link you refer to, a Dr Kunchur is mentioned as the person who proved that our ears could hear differences in arrival times of 5 to 10 usec.
Howewer in the document where he published his findings, there was a severe mathematic calculation error. What he actually proved was that our auditory system has a minimum discrimination level of 0.7dB, exactly the attenuation of the sound traveling a difference of 5 usec in his test set up.
I confronted him with his error, and after some emails he admitted that his real knowledge was in a totally different discipline and that if he visited the Netherlands he would like to meet me, which did not happen.
But nevertheless, every now and then I come across this figure of 5 to 10 usec.
Hans
Bill, who is JR?
Jn
If I say 'F=BIL' you might work out who I was talking about 🙂
Hi Bill,
You may find this interesting to read.
Human hearing beats the Fourier uncertainty principle
Hans
Fascinating. The examples given seem to be at a few 100Hz but even so looks like some could detect the difference in a couple of cycles, at least if I am reading the graph correctly.
And sorry I'm 3 pages behind today. Real world got in the way...
Cymbal was Zildjian K Custom Hybrid Limited Edition 14" Reversible Hi-Hat top.
Mic was Schoeps MK41 capsule with CMC 6 body (aka Schoeps CMC 641).
Mic and premap-to-ADC cables were custom manufactured Jam designed XLR cable wire.
Preamp was Grace Designs M101.
ADC and master clock source was RME ADI-2.
SPDIF from ADC into Focusrite Scarlett 6i6.
Recording software was Reaper 64-bit with project sample rate set to 192kHz (to avoid any unwanted resampling).
Hope that's enough info for you... 🙂
Brilliant, thanks! Data and all the measurement info. Perfect.
Nyquist denial??????Settling time will be that of the filters used, and independent of sampling per se. That's the point I find most lacking in this discussion. It's a newer, subtler form of Nyquist denial.
Much thanks, as always,
Chris
I would take great pleasure in providing you some new orifices, however, that would be counterproductive (I believe, do not prove me wrong).
The beautiful aspect of my analysis is..wait for it....
It is testable
What part of that do you not understand???
All that I speak of, all that I do, the primary goal is, testability.
If you have a problem with testability, tell us.
I believe you confuse me with someone else.
Jn
My major concern is....if there are sources which exceed nyquist as a consequence of envelope modulation, that any filtering which impacts the envelope modulation splash removes information.
Jn
Ah, ok...If I say 'F=BIL' you might work out who I was talking about 🙂
The worst thing that can happen to one is, not being remembered.
Sigh..
Jn
Nyquist is not just "sampling twice the frequency".So let's recap ...
Exactly how many angels is it?
If you (and others) do not understand that, just ask.
Jn
It is testable
I don't understand why anything has to be tested in 2020. Sampling has been established law since I was in diapers. To work right it requires bandlimiting. Bandlimiting has known, predictable effects. There is no other there there.
Chris
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part III
