John Curl's Blowtorch preamplifier part III
Question, as my google is failing me. How many cycles at say 4kHz does it take for our reptilian brains to recognise a tone, then how many more to say 'aha it's a picolo'?
I can see why a system buried deep underground might need to get everything right for a single cycle, but darned if I can work out what that has to do with Bruckner.
Hi Bill,
You may find this interesting to read.
Human hearing beats the Fourier uncertainty principle
Hans
Now, if your point is that transients we can hear require frequencies above 20kHz to be reproducible in the way that humans hear them, that would be another issue entirely. That would be to say that humans may not be able to hear above ~20Hz when measured as a single tone, but in transient cases there is some hearing sensitivity that does not apply to single tones. That would imply some nonlinearity to how hearing works. In other words, that theory only pertaining to linear systems may not perfectly apply to hearing. That gets more back into problems requiring more perceptual research. Its not really an issue about the correctness of linear theory itself as applied to linear systems.
OMG That is EXACTLY what I am talking about. And only CD 16/44.1
This other stuff you mention and Scott and Waly mention is not on point at all. All true but not directed to what i or JN has told in our own individual ways.
THx-RNMarsh
Hi Bill,
Yes very interesting.
And i'm very happy to see it confort my certainty that our hearing system is highly dependant of our culture. The best performing subject was a musician. As there is no reason he have better performing ears (the microphone) his results depends of his education (brain) and on what he focus.
As usual.
When you don't follow something, you equate it to something else. As many folks have noticed capacitors passing audio signal do not work as well when then is measurable voltage across them. Do you understand why? (Obviously not.)
George, as usual also!
I have not seen capacitors discussed lately, when did you ask?. You probably also forgot the discussion of ideal vs perfect.
LTSpice can very well create a 44.1/16 .wav file like you did, but is not the right tool tool to analyse the spectrum of this file, because it connects all datapoints with straight lines instead of ZOH.
This alters the Frequency content and shows a wrong spectrum.
Better to use a tool like RMAA to analyse the spectrum of the created .wav file.
Hans
Cool Edit Pro or Adobe Audition are better for this task.
T, I stand corrected. I did not work directly with Ampex when they finally put out the ATR-100, so I just assumed that they moved up to 2 mil lam heads as I told them to do in 1968. I have never used ceramic heads, but I was told that they did have problems like you described. I had custom 2 mil lam heads made for my modifications to the Studers that I used. No real problems with them, so far as I know. The standard thickness for the head laminations when I worked at Ampex was 6 mils. It was not enough for best performance.
In my opinion that paper makes it certain we *should* do better than CD quality, but not much more BW/risetime is required, 16/32Khz would be enough, it is a pity that the inventors were fixated on Beethovens's 9th fitting on the disc.
-3dB at 40KHz. Minimum. or 44Khz.
24b/96K+ is fine as a more suitable minimum, though. Which we have already for a long time.
If one loves disks, over computer files, get a CD recorder like this one and burn to 16/44 and burn another at 24/95 direct. Red Book and CD24.
Alesis ML-9600 High Resolution Masterlink Master CD Recorder (yes, I also have one).
But, then try the 5 times rule at about 24/192+ 🙂
Thx-RNMarsh
I find it intriguing what people can extract from this document and why 44.1/16 should not be adequate.
We humans seem to have some 4000 inner hair cells, each individually capable of hearing a certain frequency.
At the same time all nerves coming from those hair cells are not only individually processed, but also fed in one separate nerve cell through a kind of AND gate.
This gating mechanism seems responsible for hearing of rapid sound attacks instead of frequencies, but still within the frequency range that our hearing system (hairs cells) supports.
This implies that we have different mechanisms for the frequency and the time domain.
That is why we are so sensitive to the onset and decay of the sound of an instrument.
An elderly person, who lost the upper octave of his hearing range from 9khz to 18kHz, still has 3600 inner hair cells.
It has been investigated that the temporal resolution decreases with the square root of the amount of inner hair cells, so temporal resolution for an elderly person increases only by 5%.
So frequency wise, he is somewhat crippled, but because of still being very sensitive to hearing the onset and decay of a specific instrument, he is still very well able to tell the difference from one audio system to another.
But again, there is no reason to reject 44.1/16.
Hans
How did you calculate that?
Look at the graph, I am assuming that the nyquist limit corresponds to 20Khz behaviour, it seems that the content above 20kHz, whilst is can be noticed when very high ( in same room as Ultrasonic tanks makes ears ring/hurt) it is not needed to enjoy music, but it seems the timing information is much tighter than that indicates, hence more BW to preserve that. with the exact numbers of their data it would be possible to come up with a more accurate number, but that was just an estimate on my part, hence calling it an opinion, not a fact.
look at the extreme data points, 3Hz resolution, with 3mS of data, and 18mS for 0.1Hz difference, absolutely nuts that ears/brains can do so well!
Transient is the changing of amplitude of a specific frequency component. Changing the amplitude of a frequency component can violate Nyquist even if the frequency itself does not. That violation is dependent on the frequency and rate of change. While you were typing, I posted, detailing what it would take to have lower frequencies not violate nyquist by changing envelope.
Uhmmm....only if that change in amplitude would require a sinusiodal component above Nyquist. It would be imperceptible anyways because of limitations in HF hearing and will be filtered out by any adequate ADC.
