Maybe he thinks it looks like a little model of a city YouTube Pay particular attention to the lesson at the end
She is adorable. Dan, not so much 😀.
You’ve got seriously laid back mean streak! .....scientifical one might say. 😀
I saidYou made the statement, you back it up. Unless your view of good DAC layout is 'ooh pretty'
Like my statement says for the purposes of the experimenter the design is spacious and there are clearances to change or add caps and supercaps, there is provision for oscillator rolling and there is provision of connection to external dac stage pcb......board is well laid out and has space enough to enable cap rolling (including Supercap) and oscillator rolling.
There is easy access to adding and swapping other components including the regulator.....all these qualities combined on an economical prebuilt board is unusual and does count as well laid out for the purposes of the experimenter.
Close inspection will show that for two layer assy the board is electrically quite good with copious earth pours and ample stitching throughout.
For $50.00 or at any price this 'semi-disposable' board is really good sounding and is also a physically ideal starting point for the DAC experimenter.
Your turn now Bill.
This board connects to and is powered by PC/Laptop USB socket and provides audio conversion better quality than standard PC sound.
So, if I’m using Toslink or RCA S/PDIF inputs I could simply power it from a USB wall wart?
I said Like my statement says for the purposes of the experimenter the design is spacious and there are clearances to change or add caps and supercaps, there is provision for oscillator rolling and there is provision of connection to external dac stage pcb.
Your turn now Bill.
Thanks Dan, I do appreciate someone actually putting some thought into it!
So the the optical and coax on that unit are outputs?
Of course not. They work to get paid.Also, tell it to an increasing number of DAC designers and manufacturers. They are not doing it for nothing.
Would that be sighted listening?I am sure that you are quite able to simply test it yourself. But it would require hearing rather than measurement, but I don't consider listening to be nonsense, just perfect sense.
Quoted for future reference.Could you please quote a few recent examples?
We are supposed to believe you?I'm interested and if true, I'll be more than happy to correct and to avoid something similar for the future.
If I was on a forum like that, I would leave.The level of aggressiveness and rudeness in this forum has reached an unbearable level.
Nope this board is a USB data input to analogue audio and Toslink/RCA SPDIF outputs convertor.So, if I’m using Toslink or RCA S/PDIF inputs I could simply power it from a USB wall wart?
Ah, got it, thanks!
Your welcome, and yes the optical and coax connections are spdif outputs so you can use this board to feed your DAC from a PC/Laptop.Thanks Dan, I do appreciate someone actually putting some thought into it!
The other end of the board is the analog outputs, the RCAs are DC coupled, the ST3.5mm is AC coupled.
in contrast of your layout where upper transistor will be on higher temperature (only if you mount it horizontally they will be on similar temperature).
So what, on the same note it could be argued that your layout is using efficiently less than 1/2 of the heat sink cooling capacity (the upper half). Rth is decreasing with temperature, so the upper half will get the bulk of the radiated heat, while the lower half will stay much cooler, depending on the airflow (convection) around.
Talking about magnetic effects, did I mention I'm cringing when I see the output inductor on the PCB, radiating straight toward the input stage?
BTW, I am not your competitor, so you can relax 😀.
Been chatting with JC on the (hot air) blower again?All I need to hear sports game announcers.
Unfortunately, it is true. 🙁The level of aggressiveness and rudeness in this forum has reached an unbearable level.
These days, when I load a page here, usually about a half of it consists of ignored posts.
What surprises me most, is, that many of those posters are over 60 years of age. It would be about time for them to calm down. Didn't the real life teached them anything? How are they getting along with other people?
Best,
Disagreement is interpreted as a rudeness by some members here, though the same members regularly use rude language. It seems that perception of rudeness is very individual. So please let's stop crying and never ending complaining and let's bring something to the subject, but be prepared to different opinions then and to confrontation of ideas. Such is the discussion. Otherwise let's use Instagram or Facebook with likes only and option to delete inconvenient ideas.
Well based on those limited measurements I can't see anything that would make me run screaming from the room.
They didn't show the numbers with 32-ohm headphones plugged in. Found that somewhere on another website. Looked worse, of course, quite a bit so to my preferences.
There is also a row of I2C pins for quick connection of different DAC stage for DAC board rolling too !
Probably I2S pins then
George
You have lost me, where is speed impeded and what function would be hampered? And please define nonsense?
Super caps are slow.
They have high ESR for one thing.
But, they can hold a lot of charge and can be recharged faster than a battery, so that is a good area to put them to use.
Supercapacitor Information – Battery University
They are afaik not even specified for AC.
Again, the most critical voltage reference of a DAC needs ultrafast reaction. A super cap is not the answer.
But, yeh, the word 'super'. How can it not be good for audiophile use. "Super Silver Caps", would be even better. See the business opportunity! All that Oppo-mod nonsense seems to be over, so time for something new.
Edit: you asked for my definition of nonsense, but it cannot be defined, only understood; the Oppo thread was mentioned by means of example.
I think some come here especially to be abused 😉 or they haven't got the guts for self flagellationDisagreement is interpreted as a rudeness by some members here, though the same members regularly use rude language. It seems that perception of rudeness is very individual. So please let's stop crying and never ending complaining and let's bring something to the subject, but be prepared to different opinions then and to confrontation of ideas. Such is the discussion. Otherwise let's use Instagram or Facebook with likes only and option to delete inconvenient ideas.
Nope. Such events are rare.
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part III
