With stock M2 amp/DSP/xover only --- no EQ for room acoustics; minimal room affect due to narrower radiation and CD. Measured at 12 feet from center line between spkrs (listening position)
IIRC, the M2 stock amp DSP includes some flattening EQ, not just cross-over EQ and delay. EQ settings are in the amplifier configuration file for the M2.
THx-- high quality -- too low voltage and current for PA.
Mr Agitator.... good if it gets people thinking again.
As already said by ticknpop (Mr. Agitator please read the replies to your agitations), series and parallel connection of the floating outputs can provide a good selection from a combination of DC voltages and huge current capabilities (plus there are modules up to 1500W each).
MEAN WELL Switching Power Supply Manufacturer
George
Like this one? 200W Class A amp with high efficency
Almost Damir... I posted in your thread schematics, each amp channel needs two Class-D units, each one are offsetted positively and negatively respectively.
If Class D amp is used instead of variable switching power supply one is enough per channel. I hope I will test my design this winter, hopefully.🙂
Yes - lower Z caps at Fo=100KHz would be better... however there is a noise spec. I'll try a spectrum analyzer test on it and see what is there.
Measuring Output Ripple and Switching Transients in Switching Regulators
http://www.analog.com/media/en/technical-documentation/application-notes/AN-1144.pdf
and active PFC which is maintained by the switcher controller itself.
http://www.onsemi.com/pub/Collateral/HBD853-D.PDF
George
I am sure they did a really nice x-over job of getting a flat response, GD, phase, etal at 1 Meter test in echo free chamber.
Shown is the same speaker(s) but no EQ for room corrections..... you know, peaks and dips/nulls from reflections etc etc of the room.
Which points out the benefit of more narrow dispersion and CD (constant Directivity)
-RNM
No room corrections, but yes to some speaker frequency response corrections.
That's okay, of course. Nice product, although a little slow to find its way into mixing and mastering rooms.
Have to wonder if the amp with it's built-in DAC is fully satisfactory to some customers.
George
Yes. But as you know, flat response doesnt usually stay that way in a room environment.... because of the CD and more narrow dispersion, the flat response is maintained all the way to the listener.
No room/speaker corrections/EQ needed.
THx-RNMarsh
George
OK OK. The total price is going to be scary; I am afraid to look.
-RNM
JBL M2 crossover - مستندات Google
Room modes are there always, regardless CD.
I can think of some exceptions! 😉
Personally I think there is a chance all JBL may become classic unobtanium.
Currently looking at a project 2 years down the road with a minimum design life of 8 years. Crown now in Mexico has an issue with not enough capacity to rework units that fail final QC. So parts in to devices out yield is way wrong, leading to shortages.
New structure is Crown folks relocated to Texas, specify the design, an engineering group in China designs it for manufacture in Mexico. What could go wrong?
Jbl fired 3/4 of their engineers. A great boost in productivity no doubt.
Would anyone bet on the on time delivery and reliability of their products?
I did order a replacement diaphragm in February, got delivered in October.
Worse yet the specified product is one I had a bit if design input to it.
Like open space or anechoic chamber? 😉
...Personally I think there is a chance all JBL may become classic unobtanium.
Dang, Simon, that ain't exactly a list of fun facts.
I didn't realize there was that much stuff failing final QC these days, percentage-wise.
Wow, very interesting. RNM, you see that document?
It's gonna' get worse.Dang, Simon, that ain't exactly a list of fun facts.
Dear Colleagues,
I was told that people were very polite on Anglo-saxon forums, not aggressive, respecting others. In a word, well educated. ... One more fairy tail ?
And all this about what ?... Audio-electronic ! Oh, Lord !
I joined this forum in the hope to learn one or two things on a subject that passionate-me all my life, rest me from my studies on rocket science and share the little I know with gentlemen in a friendly atmosphere.
I don't think I will stay long.
Have a good day.
Tryphon Tournesol.
There are other threads.
QC is in China.
No, professional division (BSS, dbx, Lexicon, DigiTech). No profit in two years. You may start search for another vendor.Jbl fired 3/4 of their engineers.
It should be noted that companies can have design and production all around the world and still retain quality. It's just hard and requires good leadership. It's just when companies sub out purely on cost that bad things can happen. We can but hope this is a minor glitch.
- Member Areas
- The Lounge
