I'm not sure what you meant by <any> audio format, I understood that Xiph.org determined that FLAC encode input must be PCM data only, and indeed from this perspective FLAC is a codec. FLAC can be stored in other transport containers, but FLAC files by themselves are also a storage format. In this usage you could say it is both a codec and storage format.
Howie
The source can be <any> audio format, even mp3, that then is possibly, transcoded into a data-stream that is stored in the FLAC-file. I use multiple sources, like pcm, ape, ... and more.
The use of compression by recording engineers really baffles me to be honest. It just sounds like crap and why ruin a beautiful musical track??? They have no ears? The youth today like abrasive, compressed sound? I don't know ... is it really about selling records? Do these trashy recordings really sell better?
I think it is often just about plain ignorance about compressed music
I once talked about this with a recording guy. He related a case where he recorded for a band with high dynamic range, low compression at their (the band) request. Only to get a call a few days later from the bandleader complaining that his tunes sounded much less loud on the radio than others!
Possibly this will become a none-issue when the new initiatives for loudness normalization take hold. Eelco Grimm has been working hard on that, trying to get parties like Tidal on board.
Jan
This is not new, Phil spector, Joe Meek. I think Joe's goal was to still the VU meters.
Not bad cost wise, but when you get up near 4TB of music its easier to keep a backup disk with a friend. Now given our respective locations if war kicks off we are a radioactive stain ( I can see AWE Burghfield across the fields which is where trident warheads are made) so I reckon the strategy is good.
I have used multi-dropbox like this for years and it does work well - EXCEPT when a mistake is made ( in vino etc) and a file or folder is deleted unnoticed at the time. Within minutes it is gone from all the copies.
I have struggled with this problem in IT with multiple running backups of files and databases making one feel smugly secure! However, corruption or error quickly gets propagated throughout the backup files.
I never really sorted this .... it is a management problem.
A backup is not a backup until it is restored.
Agreed. Especially when your backup is banks of IBM tape robots. Which is why I use KISS with my music.
This indeed can appear frightening, but is not catastrophic; in such a case you can contact the Dropbox support desk and they can roll back your deletions, for at least 30 days.
"Recover older versions of files
Dropbox keeps snapshots of all changes made to files in your Dropbox within the past 30 days (or longer with Extended Version History or Dropbox Business). You can recover older versions of files, restore deleted files, or undo deletion events.
Sections in this article:
Return to an older version of a file on dropbox.com
Return to an older version of a file from the Dropbox badge
Return to an older version of a file on Windows
Keep a year of data with Extended Version History
Jan
Jan
This was the writeup I referred to:
https://octo.hku.nl/octo/repository/getfile?id=qLlZPGSVXFM
Jan
Understood, as Scott put it, the most highly compressed data appears as noise, however they are touting this as a 24/48 file...except all lower six bits are noise!
Here about 1/3 of the way down, the lower 8 bits actually. The DXD/MQA comparison is very telling.
Archimago's Musings: MEASUREMENTS: MQA (Master Quality Authenticated) Observations and The Big Picture...
@Jan
"This indeed can appear frightening, but is not catastrophic; in such a case you can contact the Dropbox support desk and they can roll back your deletions, for at least 30 days"
True, of course, but some of my files/folders have not been "looked at" for many many months! If one is aware of a deletion, no problem.
since we have the experts on this thread, i wanted to ask a related question.
Why is it that for the same recording, we often seem to find significantly higher dynamic range on LP vs CD or hirez downloads, esp in the case of popular music ?
I was browsing through dr.loudness-war.info and saw bruno mars for example because my son asked the question.
You said "same recording" but although the music may be the same, the master used may be diffferent. See my post: http://www.diyaudio.com/forums/loun...ch-preamplifier-part-ii-9295.html#post5101267
for more details
Cheers!
Howie
@Jan, also, if using Windows, activate file-history it will also protect folders, and it can be instructed to keep at least one copy for ethernatie.
@Jan
OK, yes, it is always possible to lose stuff; but this scenario gets close to the risk of global nuclear war 😀
And let's face it, whatever your backup scheme, things like this can always happen.
Jan
Windoze 10? I need to look into that.
Jan
This is interesting, so what program do you use to FLAC encode these different file formats?
Howie
for more details
Cheers!
Howie
Would you mind quoting the post number ? The links are acting up again on my browser.
I always assumed that the "best" copy was going to be a download not a rip from vinyl! At least for recent pop it seems that the only high dr source may be vinyl. Ironic, but at least I may now have an excuse to build Scotts new phono stage.
Those source formats are transcoded to a pcm stream (which is then packed/compressed).The source can be <any> audio format, even mp3, that then is possibly, transcoded into a data-stream that is stored in the FLAC-file. I use multiple sources, like pcm, ape, ... and more.
FLAC is *not* a container like ogg, that can store different types of streams.
Regarding heavy compression, some smooth jazz is incredibly over-compressed. Hard to listen to, for me at least. On the other hand, it doesn't sound like heavy limiting and clipping.
@hhoyt, see post #9316
@squadra, yes I know, but the point is/was, you never know what the original format was.
@squadra, yes, sorry for that, I checked, FLAC is not a container (like .zip) my mistake.
This is what I was getting at.
Howie
Post #92950
Howie
- Member Areas
- The Lounge
