Hello guys can somebody answer my question : im trying to mode my parasound hca-3500 i have no experience but want to do it
im looking to replace c8,c16 diode bridge for fairchild hyperfast diode
question is the bridge has 4 contacts 😛lus , minus and 2 of them goes to fuses , but fairchild has 2 contacts and some of them 3 . can somebody help me to solve this puzzle and tell me which i have to buy and how to plant it on the board
thank you
thank you
thank you
thank you
The bridge has internally 4 diodes. Check the schematic of a bridge.
If you want to replace it with diodes, you need either 4 separate diodes (with 2 pins) or you can use two dual-diodes (with 3 pins), these are internally 2 diodes, sort of half bridge.
Be careful if you want to use dual diodes that the polarity (direction) of the diodes is correct; some are pointing towards the middle pin, some away from the middle pin.
Are you familiar with how a diode works?
Jan
Jan
so bottom line i need to find diode with 4 pins ? cause i have no idea how to execute this and stick 4 double pins diodes in 4 contacts on the board ?
thank you .. feel like its above my head =)
Hi djovanny,
I'm not trying to upset you, but why are you attempting to perform a task you don't understand with parts that you don't understand? This seems to me like a recipe for disaster.
I'll respectfully suggest that you allow an audio service technician do the work for you. It's cheaper in the long run, and it will be done properly.
-Chris
-Chris
This time I have to reluctantly agree with Jan that changing out the diodes is a difficult task to keep track of. I actually have to do it, once again for a Vendetta Research power supply upgrade, tomorrow, and my tech and I have to sort out the diodes and their directions to replace the diode bridges. It is a hassle, even for me.
While I do believe that faster diodes are better, there are more important changes than this for the 3500 to improve it. The primary feedback resistor, for example.
John I will make a note that on this day in this year you actually did agree with me 😎
Seriously, maybe you can do that mod on the OP's 3500. Don't know your rates but why not?
Jan
Changing diode bridge with dicrete diodes is a trivial task for average DIY builders compared to some SMD soldering. Point to point wiring with short diode leads is the best method.
Thank you guys for your help , Jhon , replacing r 44 was first task on the Phil's list of upgrades and i just finished it , result was so significant that i deside to continue and replacing diods is a second on the list , i will pass on this since its above my head and will do the rest of upgrades which i will be able to handle, but this amp is a master peace i mate it with aerial 8b and adcom gfp 750 and they sound amaising for the price
Jhon One more question i want replace several caps with polystyrene rel-cap rt 0.1 mu 200v but having hard time to find them , what i can substitute them with , not too expensive, and can i use 0.1 mu 400 v rel cap rt which i was able to finde on ebay?
I'm not so sure about that. If the Vendetta Research preamp uses a 1 amp bridge in the RB-15 package {figure attached}, that's an awfully tiny patch of real estate in which to fit four DO41 axial lead devices. Study the mechanical drawing: the lead-to-lead spacing is less than (1/4) inch! And remember that you need to connect four diodes with a total of eight leads, to the four pins of the bridge. If the vertical clearance in the enclosure happens to be small, forget about it.Changing diode bridge with dicrete diodes is a trivial task for average DIY builders compared to some SMD soldering. Point to point wiring with short diode leads is the best method.
spacing is not a problem there are about 12 mm between leads , but my knowledge is ,i totally dont know how to position them properly without damaging anything , so i will pass on this one for now
im trying to do what this guys did but i cant find same parts https://the-martins.smugmug.com/LivingRoom2-Channel/HCA-3500/i-hmgbbFZ/A which is rel-cap 0.1 200v
https://the-martins.smugmug.com/LivingRoom2-Channel/HCA-3500/i-hVG72GR/A
https://the-martins.smugmug.com/LivingRoom2-Channel/HCA-3500/i-f3JqNgf/A
i was able to find 0.1 400 v same type nad brand , but dont know if safe to use them
and here what they did with diode bridges
https://the-martins.smugmug.com/LivingRoom2-Channel/HCA-3500/i-QtRPbXW/A
Last year I did buy a Mooshimeter to be able to do simple floating measurements, $ 150. No replacement for a wideband scope with floating inputs, but good enough in 80% of the cases.
https://moosh.im/mooshimeter/ watch the YouTube.
Jan
Mooshimeter 😀
Fantastic !
Thanks Jan 🙂
Jan
Thanks for this! We were looking for a platform to demo some health monitoring demos, it's always cool when someone can just "dial" in.
Hi Mike -- Sorry for not responding to your PM sooner. I've made many modifications to my HCA-3500s and changing those diode bridges was the hardest. The bridge is an MB354 or similar and soldered to the bottom of the power supply circuit board, and bolted to the chassis for heat sinking. I would not take the approach in the picture which just puts a capacitor across each diode of the original bridge rectifier. A simpler approach than replacing those diode bridges would be to put a RC snubber across each leg of the bridge. A snubber would typically consist of a resistor and cap in series, usually 5-10 ohms and 0.01 to 0.1 uF.
As for that cap, 200VDC rating or above is fine. It replaces all those metallized polypropylene caps after the voltage regulator for the front end of the circuit. You could get away with using high-quality polypropylene and foil caps of the same value.
There's about 100 parts that get cut out of the HCA-3500 and another 80 or so that get replaced. I did not change the circuit or transistors except for the the DC servo.
- Member Areas
- The Lounge
