Is that practice still used in new opamp designs? With all the low voltage magic and the new process's I would expect some new solutions.
No, there are no ground pins on op-amps just can't be.
Hasn't worked for me, subjectively either and long ago abandoned.
One of the reasons I think for SQ degradation is not separating signal and power grounds - the rail to gnd capacitors might work fine so long as power ground is kept separate from signal. But classB circuits dump nasty haversine currents into the rails, the noise couples to gnd via the 'decoupling' cap. A 19 ohm load as here is exceptionally harsh. Would biassing the AD8010 into classA help (CCS on output) ?
That high a load would have been too much standby power for class A.
Sure, for 'pure' classA - but even 'enriched' AB might mitigate the issue sufficiently.
<edit> Thanks for bringing AD8010 to my attention anyway, looks like an interesting part...
I meant the compensation cap to the negative supply.
a few complementary common emitter op amps show Ccomp to both Q base so should be bypassed both rails to gnd (or the load return)
There are some that have Ccomp split, yes. My point here was that adding bypass from the plus rail to ground always made the diff-phase worse. BTW diff-phase is probably the most sensitive of all closed-loop parameters to GBW modulation. This circuit is otherwise the simplest textbook CFA with shunt Ccomp to (if it was there) ground. Funny that folks have not seen it before it was designed specifically for the, at the time, biggest maker of analog video distribution boxes a now virtually obsolete business.
That recording test is known ( Quad , Wharfedale, Cabasse ) but not used any more nowadays.
I think that electronics are more " perfect " than the loudspeaker-room interface.
Of cause there is still the probem of recording.
Conversion processes make trouble, converting air movement into electrical and then back the other way.
You are right, but
If we are interested in qualities, then I think it's too bad that test fell out of use because it helps in overcoming the problem of habituation. And gives a chance to identify deficiencies.
Danley here, http://www.diyaudio.com/forums/multi-way/100392-beyond-ariel-219.html#post3759569 says it well:
Part of the “fun” in audio is equating what you measure to what you hear . Part of the problem is your hearing system is tuned to seek out the signal and reject the noise, not only that but part of that process is taking two input signals, each of which individually has strong angular and height dependant effects hinging on incoming angles and to construct a single 3d image in our minds. That process makes it hard to hear or tune into what’s wrong instead of what’s right.
If you have a measurement mic and good (ideally sealed back) headphones, there is something neat you can do which by-passes the stereo image and all that processing. Set up and listen via the measurement mic and headphones. First, listen to your room, have others talk, get used to the sound of voices and familiar sounds BUT not having the normal stereo image (the mic signal to both ears makes the mono phantom image and lacking pina cues, appears in the middle of your head..
When you feel like your used to that perspective, NOW turn on your stereo, play some music but only play one loudspeaker. Often you will hear coloration that you didn’t hear live but after hearing it in the headphones for a while, you may well hear it live too. In a room, you will hear more room than live too because the microphone is omni directional while your ears have some directivty.
At work, as a reality check (in the beginning it wasn’t clear we were barking up the right tree) we did a number of “Generation loss” recordings with both ours and competitors loudspeakers.
The old time generation loss test was a way to exaggerate anything that was not faithful to the signal. Recording tape was another place this was often done, the better the recording system, the more generations could be played and re-recorded before degradation was too large..
If you make a recording of the loudspeaker, play it back and re-record it, everything that was wrong before will stand out much more strongly as “wrong”.
In that generation loss recording at work, it was very rare to have a loudspeaker go even 3 generations before being unlistenable or close to it, that’s how far they are from signal faithful, even if you do I on a tower and just record the loudspeakers output.
Often enough, just listening live via microphone was enough to hear what was going to stand out on generation one on the more colored speakers. With modern 24/96 recorders, it is possible to do that many generations in/out before it’s degraded.
Loudspeakers ARE still the weak link and that makes them fun to work on i think.
Joined 2009
I know from experience adding reverb and dynamic expansion can produce a positive subjective result. Perhaps something like thermal tails or power supply recovery after a burst could have some of the dynamic expansion that enhances the perceived quality.
Good observation. I have a tube amp project that has a power supply which is expected to behave in this manner. I've rarely seen much talk about this approach though. But tube amps with inductor based power supplies can allow some fine tuning of their 'step response'.
WPW 291 is the wire in question, but a similar substitute should be OK.
No, it isn't the wire in question. It is simply a wire. The initial questions were about the coiling of microphone wire and how it made the sound terrible due to the increased inductance caused by the solenoidal currents within the twisted pair.
My contention is that there is no solenoidal magnetic field as a consequence of coiling a microphone cable. There may be other effects caused by the inherent communication capability of a twisted pair cable to conductice materials in its immediate environment, and coupling to other twisted cables with the same or integer related twist pitch (including itself.)
What is in question, is what were the conditions of the test. That is being kept secret so that it will not be possible to duplicate the results.
That's not how real engineers work.
That is not how I work.
jn
ps. now if that ain't a lob right over the plate, I don't know what is..
JN, I presume that you are not going to back up your statement with ANY sort of real measurement? That has been your 'pattern' over the years: Challenge someones findings and NEVER prove it by a parallel experiment.
Since there is in essence no experiment to parallel what is he to do in response? Remember 3+ orders of magnitude of error remain on the table.
I see we share a snub by Dr. Rich, I told him I respect people's enjoyment of SET's and horns and he never talked to me again.
Back up my statement?? I stated that Ed used the wrong meter setting for the test. HE repeated it using the right meter setting and got results that were at least within the same order of magnitude as reality. Of course, with absolutely ZERO specifics on what he took pictures of.JN, I presume that you are not going to back up your statement with ANY sort of real measurement? That has been your 'pattern' over the years: Challenge someones findings and NEVER prove it by a parallel experiment.
As I said earlier, it is not my responsibility to try to duplicate every test some yahoo on the internet posts.
In Ed's case, he explained a 3 order of magnitude test error as the EXPECTED result.. Do I try to duplicate the test using the same incorrect instrument settings??
Do I try to duplicate a few pictures of a meter, without regard to what's connected to it, or how the test is performed?
After I explained to Ed why his test settings were incorrect, HE at least had the balls to re-do the test and provide pictures. Granted, he never acknowledged that he really screwed up the test by using the wrong settings, and he never acknowledged that his explanation of the 7 millihenries was made up fiction reinforced by a bad reading 1000 times larger than reality.
You on the other hand, went off for a year or so explaining to us how your fancy refurbed ST was finding all kinds of non linearities in the connections. No matter how much I explained to you how your equipment was not designed for that level of operation as it didn't clear the ground loop problem you had. Several others used AP's and found nothing, yet you never acknowledged the fact that you were led down the garden path as a result of lack of knowledge on EM compatibility.
Malcolm does the same. Messed up the derivation by using an approximation equation that didn't even apply to the problem, forgot to add the wire permeability and it's inductive increase to the wire, had absolutely no clue as to how to make an actual test fixture capable of high rate of current slew without large voltage errors, and from then on, refuses to acknowledge 27 YEARS later, that he messed up big time..
Is that what you are all about John? Is that what your part in high end audio is all about? make up some unsubstantiated scientific explanation, put together some hilariously bad and incompetent test design, cherry pick the results which fit your premise, the present the "proof" with absolutely no information which would allow others to reproduce your "results"?
I will perform CONTROLLED, baselined, accurate measurements of my cable when I get to it. And I will detail the exact conditions of the test.
Just as I did with the cable test in my gallery, just as I did with the inductor tests also in my gallery.
jn
John is quite right on this.
I guess you too are happy with test errors of three orders of magnitude as long as they support your beliefs?
As an engineer, I cannot do that.
I also note with interest that you do not concern yourself with how your amp actually works with the equipment it is designed to work with. You appear most happy to present bench testing as the endall, without consideration of how is actually performs in the field.
JohnC doesn't even know HOW his equipment is tested, case in point the crosstalk testing.
It frightens me that others may be learning this craft from people who do not believe rigorous engineering practices are important..
With luck, the next generation of engineers will consider the actual use, as opposed to only bench testing that you seem enamored of. If that doesn't happen soon enough, high end will continue it's slide into oblivion and fashion.
jn
Continue? You mean it could get worse? Even more nonsense propagated as 'a superior truth'?jneutron said:continue it's slide
How can we convince people that a number on a meter or a trace on a screen tells us precisely nothing unless we have a good theory (a prerequisite for good experimental practice) about what we thought we were 'measuring'. A quick check would be to ask for estimated error bars on the 'measurement'. If the error bars are several orders of magnitude larger than the 'measurement' then we have just invented yet another random number generator.
I trust Stereophile to give me ACCURATE RELATIVE RESULTS compared to my competition that is measured in the same way. Once we actually build a product, we can do little to fix things like Xtalk. We have to start circuit layout stage, and be in CONTROL of the whole fabrication process. As we do NOT always have that with Parasound products, we have to live with what we get from Taiwan. This is why PMA built his own amp, so as to have control over layout and construction. It sure beats a SW Products power amp. '-)
- Member Areas
- The Lounge
