My speak was about aluminum bonding pads on transistors and IC's, with pure gold wires.
jneutron
I was reading on alloy phase diagrams and I found this (attached jpeg).
I thought to send it to you
The key elements in the formation of Al2Au is composition and temperature (during bonding or later during service).
Did you do thermosonic bonding at that time?
George
jneutron
George
Yes. Both thermocompression (T/C) and thermosonic (T/S).
T/C uses compression and heat. T/S uses ultrasonic energy.
Also aluminum ultrasonic, 5 mil up to 25 mil
My responsibility was incoming electrical inspection of the silicon chips. We would sample manufactured lots using AQL, sampling a specific number to assemble, pass on one failure, reject on two. It was a stats thing.
The higher ups had determined that the good wirebonders were for production, and that the trainees would learn on my incoming samples. As a result, I learned all of the various ways chips could be damaged or destroyed by wirebonding. And there were lots of ways. Also, when the bonder wasn't working right, I had to learn how to troubleshoot and repair the bonders.
I also learned all about the physical structure of the chips, and how sensitive to physical damage they could be on the top.
jn
Interesting to see indeed - BP certainly does have a awful lot of faith in THD and SNR as the definitive figures of merit for a DAC.... 😛
Having read their philosophy on their site I imagine that their definition of "noise" might be somewhat more comprehesive than simple steady state noise.
Rather, they talk about removing everything that isn't the music.
This sounds like a very reasonable approach to producing very good sounding gear.
Their pay rates will start rising, and soon they will form a union and demand larger offices and a retirement package.
I know you dont man it to the extream but extreame exists too;
there might be something to be said for working until you drop dead on the spot... forget unions and retirement plans; A couple years ago, I was in a Taxi in Nepal and by the curb side was dead body with a sheet over it. the person was outstretched arms and facing east....face down. he/she made it that far and dropped dead. Others along the roadway/curb were not even concerned.... but one person beside the covered person was very distrought but what could he do? [trust me, you dont want to know what they do with the body].
So, yes, lets all forget about a safety net et al... work 'til you drop... sounds third world to me.
-Richard
Thank you.
I searched for this article that fits well to your job description
http://articles.adsabs.harvard.edu/cgi-bin/nph-iarticle_query?1997ESASP.395..411J&data_type=PDF_HIGH&whole_paper=YES&type=PRINTER&filetype=.pdf
(See the mention of temp of 125 d. C as a limit, above which Al-Au intermetallics can degrade the bond.
Notice also the positive comments on mass production and stats)
And here are some test data plots that warn against high operating temperatures which promote the formation of intermetallics. In combination with contaminations they cause bond failure
https://www.reliabilityanalysislab.com/IntermetallicsandWearout0302.html
George
Yes the engineering is good no doubt. But, it looks like BP is cast from the same mold then as DS. Only sub PPM will do. It's a pretty dimensionless view of things IMV. The result has been, and especially in the DIY community, all these frightfully convoluted designs to achieve sub ppm distortion in the simulator, most of which, because of their complexity, never get built.
As always, it will be about the implementation. The design may be brilliant, but if interference effects kill its real world performance then it won't make such a big splash. The trouble might be, that they will have to spend just as much money and effort chasing down and eliminating all the audible artifacts resulting from 'cross contamination' between electrical areas ...
I doubt BP will have any issues with getting things clean and quiet. It will probably sound quite good as well but I don't think that's necessarily because its low distortion. We will just have to wait and see how it's received and what people think about it.
My own experience with class D was with S and P in Japan, but it was very high volume consumer stuff - certainly not pitched where BP or Devaliet (sp?) are.
