John,
Behind the Iron Curtain the availability of western made drivers was minimal and priority came to mainstream PA Stuff...
In East Germany the biggest HiFi Woofer was 8"... In one of the Baltic Republics of the Soviet Union they made a 10" Driver that was a copy from a Sony Speaker... Some Pro Drivers where bigger but had very resonances.
At the time I owned also Schulze TH315 in Studio Boxes (12" Coaxials developed over time from the original Eckmiller Design) and boxes build from an EV Kit with an EV 15" Woofer, 8HD Horn and T35 Tweeter. But these all looked industrial and where in what was supposed be my Bedroom, but which was small mastering studio instead...
The active speakers where for my living room. Slim Towers, back full off heatsinks, Chip-Amp's for power.
Ciao T
Parasound sold a 30" woofer once.
Ciao T
At the time I did not know the Backes & Mueller approach of sticking the microphone directly to the cone. If you do that and design the PI Regulator circuit you can stay stable to many 100Hz...
Ciao T
Some of the GE medical pressure transducers make decent DC - 3KHz microphones.
Ditto the AD MIMS accelerometers. The +/-100g unit is appropriate.
Fostex still makes a 31.5" woofer.
$3,464 at Madisound.
se
Anything else than voltage drive of the dynamic speaker is a great nonsense
Surely you have a reason for such a blanket statement.
From what I've heard those Fostex 31" don't really sell. You can't get one. Just a show piece. Would like to hear from someone who actually has one or has seen it in use.
Madisound apparently doesn't actually have them - they will order one
for you.
The road to hell is paved with good intentions - Wikipedia, the free encyclopedia
I have seen and heard one at a trade show in Tokyo in the middle of the eighties. It might even have been at its introduction. Very impressive. Even when not playing very loud, it would fill a whole trade fair hall with bass. Haven't seen or heard one since, unfortunately.
vac
Agree for the most part, certainly for woofers it is most dangerous. At the high impedance peak(s) caused by the one (closed) or two (BR) fundamental resonance(s), voltage would sharply increase at the exact moment when excursion is already maximum and badly damped. Results like VC's bumping backplates or cones crumbling are likely. Hence my earlier question to Thorsten how many woofers he had destroyed in the time when he says he used current drive for all his drivers. There are some other additional good reasons not to use current drive with woofers, such as the effect it has on Qes.
Hawksford in his paper identifies some interesting properties of current drive though, such as flattening out Bl irregularities.
Please note that in practice all mid and high drivers in passively filtered more way system have current drive to some extent, since they are usually attenuated in order to line up with the sensitivity of the woofer. And some manufacturers seem to have calculated this into their designs. I have measured a fair deal of tweeters that slope down in the upper octave when driven by a pure voltage source, only to become straight by placing some resistance in front of them.
vac
Although this is second hand, a speaker designer friend of mine told me that some of the best bass he's ever heard was in a system that used a pair of these. The enclosures were a simple truncated pyramid. It wasn't really an enclosure per se as the bottom was left open and the drivers mounted at the top. The bottom was held up off the floor by about 4 to 6 inches with some simple feet.
se
In specific cases, it may be tuned for the unique application. But in general, current drive of dynamic speakers may not be recommended.
best bass
se
best = most? The room rattlers at BA did pretty well. Dick Burwen uses 30' concrete horns which are part of his foundation. There was a French fellow doing this even bigger, lost the pics.
I have only one pair of 12" drivers in the concrete horn under my floor, it is more than enough for movies...
- Member Areas
- The Lounge
