See, I told you Demian was a test equipment guru!
And we also have another QuanTech guru.
If only someone would build a new product that did the same thing for less than $40,000. I wanted to buy a phase noise analyzer for digital work but had to blink a few times when I saw the sticker price -- $92,000.
Of course it is tax-deductible! But I don't think I would use it enough to justify it. Probably better off to rent it for a month for a few thousand dollars to see if it is really something I would need.
I am about to reveal one of the great secrets of really cheap test methods. Just use an FM tuner set to the frequency or even a harmonic of your clock! If you want to get fancy use an audio spectrum analyzer on the output.
I have tried that with a fancy modulation analyzer. Either its not sensitive enough or my crystal oscillators are much lower noise than the noise floor of the analyzer (Boonton 82AD hot-rodded with low noise opamps). I think the limit is the PLL oscillator in any of these types of tricks. We are looking at levels as low as -170 dBc. Also doesn't work with generic spectrum analyzers since this is all about close in phase noise. It may work for finding a bad crystal oscillator. . .
Thanks, for the info. I had better luck on a high harmonic and the results even to the ear were quite informative. Of course it was an old fashioned non PLL tuner!
I'll try the harmonic trick. it may magnify the modulation so there is more to see. The analyzer has a 1 MHz IF so I need a LO that is 1 MHz from the crystal. This should be interesting. I'll try a low PN synthesizer for the local oscillator and see what I get. if I didn't have this stuff the double balanced mixer and good reference oscillator would still be the cheap solution. Good tuners still get a good price.
For an FM tuner the target frequencies to look at are:
44.1 chain- 90.3168 MHz
48 chain- 98.304 MHz
The analog tuned tuner can be dialed in directly but a digital tuner will be complaining since the 44.1 chain ends up 16 KHz off of the center. Most fm tuners have an afc (similar to a PLL) which will limit the low frequency sensitivity. It will be interesting to see what comes out. A new use for an old technology.
Will this work?
Thing to keep in mind is that Eurotten retail prices are the US figures (minimum), but in Euros instead of Dollars.
$20K turns €20K (if you're lucky), half priced for a mint late production item incl. phono stage isn't that bad. (the tacky color is, yikes :clown:)
I'm still trying to track down a semi-used KX-R in Eugh dress code at a jolly buck figure.
The CTC preamp that is being sold in Europe does NOT have a phono stage. Only a phono input designation that is another line level input. Joachim can you confirm this? It appears to be the one from our guy in Hamburg. He is asking what he paid for it, from me, several years ago.
