Audioxpress magazine has covered this in the past one really good piece by Chuck Hansen and a longer series by some other idiot.
Yes, there are some idiots out there. Maybe not only out there…
You have no idea...
I assumed your favorite source was from natural gas.
Solar works best
I'll second that. I wish this TV show was not so obscure, but an episode of "Adventures in Paradise" was about an audiophile living with his wife off on some pacific island having a new generator delivered by small boat (our hero) so he could again get back to his LP's (ignoring the wife of course). What ensued had me LMAO, this was 1960 mind you.
John,
RE: Buckling behavior linearity (forgot what the discussion was though!) FYI Buckling Analysis with FEA | Machine Design
A bus station is where a bus stops.
A train station is where a train stops.
On my desk is a work station.
ES
ES
Nope! Too etherial.
From Murphy's Laws;
Enough research will tend to support whatever theory.
Research supports a specific theory depending on the amount of funds dedicated to it.
Murphy Laws Site - Murphy Laws
Here I found some of that idiot's stuff on AC power lines
http://www.audioxpress.com/magsdirx/ax/addenda/media/simon2943.pdf
http://www.audioxpress.com/magsdirx/ax/addenda/media/simon2944.pdf
http://www.audioxpress.com/magsdirx/ax/addenda/media/simon2945.pdf
Line filters and isolation transformers aren't idiotic at all, when well designed and built.
When i walk into the room the sounds gets better.
Are you "the most interesting Man in the World" (Dos Equis beer commercials) 🙂
That is the opposite of the Placebo Effect. A heavy real mass enters the room and a lot happens.
Well you have the "Real Housewives of Blowtorch" right here, commercial free.
Fewer of those than you think.
Actually when the equipment in the room is designed by me many people have told me it is true, honest. So is that the Chanceler Effect ?
One way to test whether someone has good grounds for their views is to challenge them. The more angry their response the weaker is their case.
Indeed so, though I would add to anger here dismissiveness, impatience and name calling. Especially that esteemed name beginning with 'T' 😛 An emotionally fuelled response is the sign of an unreasonable case.
"This room is the best room for listening to music in the United States and one of the two or three best in the world according to Leo Beranek the famous acoustician."
Was ABX testing used?
Nocebo
"In these cases, there is no "real" drug involved, but the actual harmful, unpleasant or undesirable physiological, behavioural, emotional, and/or cognitive consequences of the administration of the inert drug are very real."
rgds
jms
Nocebo
rgds
jms
Nocebo
Thank you, jms, we had been calling this a "Pessebo" in ignorance of the existence of an actual term. Our choice reflects the propensity of some pessimists to be certain that an (or any) imagined change is for the worse. When doing demos in rooms upstairs at the AES, we ran into these types every year.
Also see: "everything sucks, and then you die." 🙁
Howard Hoyt
CE - WXYC-FM 89.3
UNC Chapel Hill
www.wxyc.org
1st on the Internet
...Nocebo..."In these cases, there is no "real" drug involved, but the actual harmful, unpleasant or undesirable physiological, behavioural, emotional, and/or cognitive consequences of the administration of the inert drug are very real."...
Howard Hoyt
CE - WXYC-FM 89.3
UNC Chapel Hill
www.wxyc.org
1st on the Internet
snip
However, John Meyer once told me that he put a plexiglas port on a Klipsch LaScala horn system and noted the cone movement during a live performance. He said that the cone was very stressed by input under the loudspeaker cutoff.
Very interesting and explains something that puzzled me. Doing measurements of my Klipschorn, I found a surprising amount of sound below the design cut-off (like 37 Hz). Perhaps the radiation resistance the cone is "feeling" gets low, the cone goes into bigger motions, and some output continues below cut-off.
jms
Full or empty? An interesting concept, a hall designed to sound best empty.
Beranek didn't say which way. Definitely an issue though because halls can sound audibly quite different under different circumstances. Many halls have adjustable baffles and banners which can also be used to control acoustics.
Beranek has a link to his paper on his web site in which he compares 59 concert halls using 20 measured parameters and the opinions of "golden eared" conductors and other afficionados of live music as to their relative ranking and opinions of each. In the paper he tries to find a correlation between what he measured and the preferences of the golden ears. No individuals were familiar with all of the halls, probably most if not all with only a fraction of them. They are all over the world. The number one correlation was what he calls "BQI" or binaural quality index. This is equal to 1-IACC where IACC is interaural cross correlation. BQI is a measure of the stereophonicity of the sound. The second highest correlation factor was bass response.
Personally I prefer to listen in an empty hall because there is more reverberation. I've admitted that I am a reverb freak and have always loved listening to sound in highly reverberant rooms even if they do at times blur definition. That is one reason why I find the sound of most recordings absolutely dead compared to live music. The best way to hear music in an empty hall is to find a way to get into rehearsals in the main hall. Another is to attend concerts when 24 inches of snow have just fallen on the ground and the concert wasn't cancelled. 🙂
BTW, Beranek made this comment during his Guggenheim lecture in 2001 at the mechanical engineering department at Georgia Tech. I'm afraid it's been removed from their web site. I must have watched it at least a dozen times. An excellent quick tutorial about concert halls and music.
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part II
