We joked about it too. Perhaps we could get Boltzmann to turn over in his grave! We failed however. '-)
Ouch... You typed it faster John, I had the same idea! I was going to suggest that your experiments indeed turned him over. 😀
But who knows? Modern scientist Dean Radin insists that minds and random processes are correlated!
Amazon.com: Entangled Minds: Extrasensory Experiences in a Quantum Reality (8601400924655): Dean Radin Ph.D.: Books
You can read this for free: Brian Josephson's home page And he even has a Nobel Prize in physics.
Some minds do seem random.
Josephson went batsh*t insane after he got his nobel. But you can't sack a Nobel laureate so the University just let him get on with trying to levitate tables using his mind and other such stuff.
One scientist from NASA that I know personally told that they got an "impossible" engine design in meditation.
Kurt Gödel didn't end up so well either.
If only he was not so enamored of Constance !We joked about it too. Perhaps we could get Boltzmann to turn over in his grave! We failed however. '-)
EmDrive - The Impossible Space Engine - YouTube
Emdrive - Home
RF resonant cavity thruster - Wikipedia
That would appear to be the case.
What about Roger Penrose? Some of what he says doesn't seem so far from Josephson.
He's still doing serious work at a high level. Certainly his work in consciousness
is speculative, but it is still serious.
That would require a coupling to an external spectral (non white) energy source, wouldn't it ?.It's just statistical probability isn't it? Maybe we can change the rules. '-)
Dan.
IIRC JB made a bunch hot chipping cars to get around the emissions stuff, motorhead misanthropy at its best.
No, it wasn't to get around emissions but to increase the twin turbo engines HP output.
Usually there is enough slack in the system to do that. Its when you go changing cams, changing ignition curve and fuel/air maps and adding headers etc that emissions go bad. The only thing I found that would allow a race engine - high HP - on the street was to use large and special construction while allowing high flow... catalytic converters.
Waly -- The CTS-V is a lot less weight yet starts out with 640 HP....bumping that another 100HP should be easy and stay clean. More than 750-800HP and the use of the big hi flow special cat. convert would have to be added.
THx-RNMarsh
Ok, give it a couple of days and I will post up some files.
Dan.
I forgot to mention, the idea was the data is identical before and after, but some hidden information is added. If the two files have different data the experiment is a waste of time. If the process is simple digital copying I would say there are pathologically broken components involved or other outside agencies.
I don't get it, why don't you buy an M1 Abrams, it would be a huge ego booster and would make you truly and rightfully respected on the road?
I find these linear (with a circle) white symbols on a black background a little aggressive/intimidating
???? This was was back in the days of CB, the ads appeared right along with the illegal power CB amps. No chips in my Gremlin all mechanical/bimetal/etc.
The ouroboros is more than a circle. They're all just band logos. There, now the bands have no political implications at all.
There were a couple of experiments.
One was to copy wav files from HD folders to USB TD folders and back to HD over multiple generations ie
TD plugged directly into PC USB port.
HD-00 > TD-00
TD-00 > HD-00A
Insert custom USB m/f extender.
HD-00 > TD-01
TD-01 > HD-02
etc .... ..HD-10
HD-00 = Original files already on HD.
The folders were pre created and the folder number denotes the number of transfers of the contained files using custom extender.
The other experiment was to do the above with the outboard device being an Android phone using custom USB-A > USB Micro cable.
In both cases the 'untreated' transfers sounded same, and the 'treated' transfers got progressively 'better' but majority change is upon the first transfer.
By 'better' I mean cleaner, clearer, etc and more 'stable' sounding (and more fun), subtle but not subtle.
My work mate got to hear a bunch of different phone transfers on a junk car stereo on the way to work and indicated strong preference.
Yes, it is simple copy and paste file copying and nothing is 'broken'.
It seems that there is some kind of deeper information embedded in the files that alters behaviour of downstream equipment, some form of 'quantum encryption' ?.
I have done analog domain experiments with different 33/45/78 formulations and they all sound different.....vinyl 'house sound' ?.
I have problems with HD sectors read errors right now (PC crashes when it feels like it 😡 ) so I need to solve this before redoing the experiment and posting.
Dan.
HD-00 > TD-00
TD-00 > HD-00A
HD-00 > TD-01
TD-01 > HD-02
etc .... ..HD-10
Binary file checker showed no file differences, the only difference I can think of would be file meta data.I forgot to mention, the idea was the data is identical before and after, but some hidden information is added. If the two files have different data the experiment is a waste of time. If the process is simple digital copying I would say there are pathologically broken components involved or other outside agencies.
Dan.
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part II
