What say you much smarter gurus here than I am? Do we just do the best we can and match at a low level or do we have some way to make the external LCR tank track what is happening in the dynamic driver over the operating power levels?
Not really a guru, but I think there might be some rough cancellation of coil tempco possible. But changes in suspension and compliance would be harder.
But aren't there better materials available that would reduce the hysterisis or compliance variation in speaker suspensions?
How about Soupy Sales or Engineer Bill, that dummy on Howdy Doody probably was the inspiration for Chucky from someones childhood nightmares!
Keantoken,
There are lots of things you can do to improve on the surround termination and even the spiders properties but those still don't counter the electrical changes that happen in the majority of drivers due to the changes of coil position. I have a couple more experiments to do with some spider designs and an idea I have for an alternative to the standard half roll surround for larger excursion without making the surround really wide which is a no no in my understanding. Making a surround that allows larger excursions and doesn't cause rocking or to much out of phase response is the concept I am working on but theory and reality are not always what we get when we attempt to make these kinds of changes.
That's disappointing to hear. The speakers sounded very nice.
edit: Where did you find it? Their website just shows speaker products.
They have a sub forum on the Audio Circle site. The claim of casting rather than extruding the wire seems specious.
...Von Schweikert Audio is pleased to announce the introduction of a new line of laboratory-grade audio cables, developed by a division of a leading aerospace company.
...Although Master-Built has been working on cable development for Aerospace use for many decades, the new audio cable division was developed by an audiophile, who is also their Wiring Division’s chief scientist.
... It is this noise pollution that is eliminated by the Quantum Noise Reduction technology inherent in every Master-Built Audio Cable.
...caused by collision of the electrons carrying the musical signal with the impurities and crystalline barriers inherent in any extruded metal. MB’s solution is to use the purest, Laboratory-grade cast copper, with 99.9999% of the impurities removed. Please note that our listening panel rejected all other metals in the blind ABX tests, including silver, silver plated copper, aluminum, gold, and platinum conductors.
...Dielectric absorption of the high frequency component of the music signal by the insulation material creates a non-linear response. Since most elements have “free radical” electrons in their atomic makeup, the musical signal will be affected when the electrons collide with the dielectric’s “free radical” electrons. This distortion creates a “fog” over the music that masks realism. MB’s solution is to use hyper-expensive dielectric materials that do not alter the electrical signal. Our proprietary formulation consists of vacuum-formed Teflon, which is as close to perfection as possible in reducing dielectric distortion. Our Teflon coating is applied with a Patent Pending method that does not result in free radical Teflon electrons placed in the signal path.
... Arcing (signal path distortion caused by “stranded wire bundling”) occurs when the signal electrons attempt to jump from strand to strand.
... As the electron signal flows through the wire, they generate a magnetic field if the positive and negative conductors are in close proximity. As this field builds and collapses with every musical note, the next note is attempting to flow through the cable from amplifier to speaker. The expansion and contraction of the magnetic field is called “hysteresis”
Can we know which aerospace company, so we don't accidentally travel in one of their aircraft? One of the unwritten rules of the Institute of Physics is that Members are not allowed to travel in vehicles designed using alien technology.
There is seriously nothing in that quoted blurb that's not a lie or a stunning misconception, right down to the "the" "a" and "and." The free radical nonsense is just one bit.
It pains me that there are people out there who are stupid enough to swallow this kind of huckstering, so that there's profit in spreading ignorance.
I blame schools. Kids are no longer educated, but merely trained to jump through hoops. Hence they leave school ignorant, knowing lots of words but no meanings, which makes them easy prey for hucksters. In some cases I suspect the 'retail hucksters' may have been conned by 'wholesale hucksters'; it is easier to sell snake oil if the seller drinks it himself, as then he doesn't have to fake sincerity.
Adults, of course, generally believe one or both of the following myths:
1. I am wise enough to spot something which is obviously untrue.
2. The authorities won't allow people to say things which are obviously untrue.
I did try very hard to teach the children to understand marketing speak when watching TV together. Only so far has worked on one of them.
In the case of cables it's easy to understand. Most of the profit on a system sale comes from the cables and accessories. Same as when you buy a TV they desperately try to sell you a £50 'special' gold plated HDMI connector. They probably make more on the cable than on the TV!
The shame is, like Marvel comics they have to come up with ever more outrageous claims.
marketing speak
My neighbor two houses down the road returned from Trinidad a week ago, had to go there to solve a problem at the LNG facility in Point Fortin on the isle. In february, his employer Shell completed the takeover of the BG Group (British Gas), a large shareholder of Atlantic LNG on Trinidad.
The neighbor is ocassionally asked to do assignments out of his current job description. Ranges from riser calculations in his office at the Shell E&P complex in Rijswijk, to visiting plants abroad.
At an earlier date, he told me the younger collegues lack the hands-on calculation skill and knowledge, no longer thoroughly taught at university (not as much as PP anyway :clown:)
My neighbor graduated from my faculty in '82, must be in his early 60s by now. He commented that the recent earthquakes on Trinidad were rather frightening.
Science news. You can measure groundwater levels by changes in the size of LHC.
All the particle beam machines need levels of precision in the micron range around the entire structure. Synchrotron machine beamline users, some are sensitive to the nanometer range. We are about 10 miles from the south shore, and some of the users have issues with the periodicity of the waves on the beach. They see the deflection of the beam as a result of the waves, especially if the surf is a foot or two. Being two miles from the nearest expressway, we also have problems with rush hour traffic, specifically trucks taking things east in the morning rush.
These two things are the reason the International Linear Collider can't be built here, they need beam stability down in the 2 to 3 nanometer range.
JN
Cable is 3 twisted pairs 14 gauge and 2 overall shields that are insulated from each other.
Now for your "test". You will be graded.🙂
1. Why shields? the load impedances are two orders of magnitude below the cable impedance, e coupling is not an issue, the braid cannot m shield.
2. Why 3 pair? Are you tri-amping it as you typically explain you do?
Bonus questions:
3. Why did I specify those load resistor values, and why do I recommend the use of 4 pairs of wires?
4. Why is simply purchasing a cable with three twisted pairs shielded/insulated not a guarantee of inter-pair crosstalk in the audio band at the load impedances being discussed?
No. Actually, It's a good process for getting near-room temp superconductivity. Turns out some scientists have used a scanning tunneling electron microscope to view cooper pairs on HTS materials, and the found some key points necessary for superconduction.
Cooper pairs, as it turns out, join up when there is a slight lattice mechanical vibration (in the 20 to 20K region), when there is a lack of photons in the visible spectrum, and when especially when the surface structure is wetted with an alcohol mixture modified by some proprietary surfectants (sp) and volatiles. Seems the manu stumbled upon this very special set of circumstances when they cast and cool the copper.
Some mood music, dim the lights, add some alcohol, voila...the electrons pair up...
Note: I just know some kook is gonna take that explanation and run with it.😱
Then how do you even get into cars. Anybody who learned cars under the hoods of vehicles pre-1980-90 has already learned that present day cars are filled with alien technology. I have no chance of understanding those darn computers...
John
