One of the application of an LED is to bias a bipolar transistor, e.g. to make up a current source, using a emitter resistor to set the current.
For perfect bias stability, the LED and the BJT should have the same tempco.
If I am not wrong, the tempco of a PN junction is -2.2mV/K.
(Current Sources and Voltage References: A Design Reference for Electronics ..., Linden T. Harrison)
Opto-couplers tend to use GaAlAs LEDs at ~880nm. Their tempco is about -1.8mV/K.
The only LED I can find in literatures that has close to -2.2mV/K is GaN at 375nm.
We have done some simple experiments with a CCS made of BJT & 630nm as well as BJT & 375nm.
The latter was more stable over a temperature range of 30°C.
Wonder if anyone else has similar experience or even better solutions ?
Thanks in advance,
Patrick
The good old two transistor CCS does not have any problems with light interference. And if you run enough current through the main pass transistor it will even glow for you like an indicator 😀
Ditto for a 4 transitor ccs, two PNP on top of two NPN, which adds quite a bit of dB of PSRR, but at the obvious costs of double the cheap silicon. The price difference works out to nothing in the overall scheme of things.
