Don't worry Scott, we know that even if we put them up, you will 'misread' them and contradict what was found.
If the information contained is valid then it will stand up to scrutiny.
My view has not changed, and still no information to the contrary.
SY’s intention is to reintroduce the term ‘HOMO’
What's Greek for LUMO?
BTW, kids, although calcium has good conductivity, don't try to make wires out of it!
Holes usually have less mobility than electrons.
And now, valence does not matter? What do you know?
That you're mixing up several different concepts with different areas of applicability?
Curiosity killed the cat
1. ‘λιμ-’ : ‘not enough’
2. ‘λήμα’ : ‘strong desire’, ‘intention’, ‘courageous action’
3. ‘λήμμα ’: ‘profit’, ‘benefit’
4. ‘λύμα’ : ‘the obligation arising from a (legal) binding’
5. ‘λείμμα’ : ‘what remains of’
6. ‘λύω’ : ‘loosing the binds’
7. ‘λοιμο-’ : ‘detrimental’, ‘malicious’
8. ‘λοιπο-’ : ‘not in excess’
Henry George Liddell, Robert Scott, A Greek-English Lexicon, ? ?,
George
Compared to nano amps, micro amps are high current!
If I have 1 nano amp current flow how many electrons per second is that? (10^-9 x 6.24^18 q/S) What is the speed of propagation in a copper wire? (2.4^8 M/S ish) If we calculated q/M (6.24^9/2.4^8 q/S x S/M) for a given wire length. We can then add cross section and get charge per volume.
sigh...no need to correct your error, others did..
Probably correct.Wrong answer. Here these guys have nice review material I've used it before, Ohm's Law, Microscopic View
EDIT - I just realized how confused you are on this, best to just let you carry on.
Scott
One of us is confused. Your cite uses 3e10 as the velocity. I used 80% of that. We are not talking about particle velocity.
JN posts examples that support where I keep trying to go in this crowded room.
You used prop velocity for a calc of charge per unit volume, not accurate.
Rather than try to make it a 20 questions schtick again, perhaps a simple discussion would be better for you.
jn
jn
I don't know about you, but I got the jist of the proposal as there are distinct signal electrons that propagate at c from one end of the wire to the other that "interact" with the conduction electrons in some way. Hence my Maxwell's demon reaction. I still wonder where in the recent literature this came from.
That would explain the Bremsstrahlung x-rays emanating from the end of signal cables..
They seriously think it's possible for electrons travelling at good fractions of lightspeed to run through a cable without emitting x-rays?? Perhaps they should look at the target of an x-ray tube.
jn
What about 12 midnight ?That's a nice problem, I solved a similar one using primes in high shool. Prove that the three hands are coincident at only noon (12). Of course these problems are different on a military analog clock.![]()
You need to be outside to tell the difference. I'm surprised jn hasn't solved the clock tri-section problem, it would probably yield to the same prime factor of gear teeth as the first one.
So the answer is 12 o'clock not noon then ?
Yes sorry joking around a little, a 12hr. clock is the same AM or PM.
Well it was high school . Not that bad a joke really .Yes sorry joking around a little, a 12hr. clock is the same AM or PM.
Speaking of vitamines and minerals.... just looking at chemical formula's.... can you increase fuel octane with caffine?
-RM
Yes !Speaking of vitamines and minerals.... just looking at chemical formula's.... can you increase fuel octane with caffine?
-RM
Eco-Farmers have found that feeding their pigs
from Starbucks dumpsters increases the octane
of the fecal methane produced !
well in that case, i'll just have to tweak the ignition timing to get optimum power output from the increased octane, I guess.
If I remember correctly, it provides extra oxygen and hydrogen. Then you can richen the fuel some more. Whereas an additive like Toluene only add hydrogen which is fine for suppressing detonation, only.
Hey, where did everyone go? isnt this the HiPo engine forum?
Oh.
Never mind.
Back to calcium, or what ever.
THx-RNMarsh
Oh.
Never mind.
THx-RNMarsh
Or else 4558's are perfection by which all else should be judged !I just received some info that certain ABX tests are done with a comparison system made of 4558 IC's. Now I KNOW that the ABX'ers are on the wrong track, and I have proof.
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part II
