Isn't that the homeopathic drug market? Except maybe people have a real sickness and that makes it worse.
Yeah, I suppose it works pretty much the same way. It's all about exploiting peoples' neuroses.
se
In some cases : Sylvia Millecam - Wikipedia, the free encyclopedia
In most cases, one might assume there's a real 'cause' for putting faith in homeopathic drugs.
Which operates on the same floor level as scam games and audio gadgetry, imo.
Different market, identical principles : different story, same routine.
Nice box. Learning from the rest of us, Bruce?
No.
Part 1
Part 2
And I have patents to cover my work. Something that Mr. Bybee doesn't, there!
Audio connector with ganged articulation networks
https://www.google.com/patents/US20090227142
Audio signal cable
https://www.google.com/patents/US4538023
High current demand cable
https://www.google.com/patents/US4718100
Audio frequency cable with reduced high frequency components
https://www.google.com/patents/US4994686
Audio signal transmission system with noise suppression network
https://www.google.com/patents/US4954787
Audio signal transmission line with a low pass filter
https://www.google.com/patents/US5142252
Audio transmission line with energy storage network
https://www.google.com/patents/US5956410
Audio signal cable with passive network
https://www.google.com/patents/US6658119
https://www.google.com/patents/US7242780
Please enjoy a quote from one of my patents:
BACKGROUND
The modern Western Chromatic scale has been around for some time. However, there was much debate initially regarding the “interval”, or space, between neighboring notes.
For example, Pythagoras, Philolaos, Boethius and Zarlino, who were rationalists, justified their systems based on numerical relations (2/1, 3/2, 9/8, 5/4, etc.). Zarlino justifies his system of scenario using only the first six numbers; there were only six planets known at the time.
More complex scenarios, such as the notion of overtones and acoustics comes later, in the XVII century, with Sauveur. Historically, other tone systems were proposed giving rise to other categories of consonances.
For example Archytas, a student of Philolaos, noticed that all the “Pythagorean ratios”, such as 2/1, 3/2, 4/3, and 9/8, are epimore (superparticular [n+1/n]), and built another system based on the superparticular ratios.
He also built another system based on the Pythagorean scale that contained four fifths and five fourths, giving more commensurabilities than can be attained from any other eight notes.
Eventually, the modern chromatic scale emerged that divided the space between octaves (a doubling of a note) into twelve intervals. Each note in the chromatic scale is referred to in music theory according to its relative position in the scale, i.e., the note after the root note is the “second”, the next note is the “third” and so on.
Sounds like brute force cybernetics " We create a need and fill it " then there will be phase II the improved " Super duper ultra high definition” mode tm applied for . For say 10k up grade. Including DMI ( dealer margin improvement ) with virgin oil of asp at no extra charge.
Hah! I spent many episodes wrestling with an Atomic coffee machine, trying to get the damn thing to do something useful to the milk! Gave up, and the thing managed to rust itself solid - still have it, at least it's worth a few bucks now ...We all have our little problems, just when I thought I had found milk frother nirvana, the thing triggers my espresso machine to stand-by flushing.
I just want Coffee out, and Froth in, will have to install a Backbee.
Hey, anything in writing is true - it's called "data"! If you say anything nasty again I'll whack you over the head with my Millman & Halkias, from just behind the screen here ...It must be true, it says it on the profile! 😀
Are we there yet, are we there yet, are we ...? 😉Well everyone, it is now obvious that my opinion will not sway anyone about Bybee devices. That is OK, now let's go on to something else, hopefully something that could be useful to make better audio quality.
It will be nice for you to get something useful out of it for a change.
Some people do hear "real" problems - get over it ... 😀No no, that ain't how it works. It's more like this:
1 - Make up a "problem."
2 - Tell people how horrible it is and make them afraid of it.
3 - Offer them a "cure" for the "problem."
se
At least one approach that can work, that I've found quite successful, is to be aware of what the goal is, a firm idea of what level of SQ is possible, if no compromises are allowed which undermine efforts made.
Then the process is to isolate each deficiency that is causing an issue, and resolve it. When all are taken care of, the desired result ensues.
The seemingly typical alternative which is to focus on one area of the overall puzzle, and concentrate all one's technical knowhow and expertise on bringing that one mechanism to as close as perfection as you can, while ignoring everything else appears fraught with problems. As in, the end result, the completed audio system still doesn't sound so brilliant - so, perhaps the smart thing to do then is blame bad recording technology, or that speakers are notorious for bad distortion ... 😉
"Seemingly alternative" is right.😕Then the process is to isolate each deficiency that is causing an issue, and resolve it.
No, I'm talking about the amplifier guru 'only' worrying about the amplifier, the speaker expert obsessed with playing with those bits of kit ...
Frational Articulation, pure BS that should be actionable fraud.
LOL
I thinks it's hilarious.
LOL
It gets even better.
RMAF11: High End Cables, Pythagoras & the Value of 2¢, Bruce Brisson, Gavin Fish, & Tony Weber - YouTube
se
They've even appropriated the MIT abbreviation. Some people have no shame.
But, audiophiles are GULLIBLE and suppliers like this are are like the banking industry: PLAIN DISHONEST AND CRIMINAL.
Period.
Period.
Fraud Department -
Maybe. But you would have to overcome the US Government Patent Office agreeing to its claims as a legitimate useful design to be successful in court as fraud. Wouldnt you? Not so easy to do in practice and a lot more costly. Now someone without patents would be an easier target.
Thx-RNMarsh
Thx-RNMarsh
Not really, no. You don't have to prove your patent actually works. You just have to show that it's "different." And even then, the patent office is largely just a big rubber stamp. John Bedini was able to secure a patent for what amounts to a perpetual motion machine. Ray Kimber secured a patent on a cable geometry that had already been patented.
Bottom line, having a patent doesn't mean a damn thing with regard to whether or not your device actually "works." And unless you have some pretty deep pockets to defend your patents, they're little more than marketing fodder.
se
And perhaps the best example showing what a joke the patent office is with regard to patent claims, Bedini was able to secure a patent for his "Clarifier," which did nothing more than spin a CD in a fixed magnetic field. Yet he claimed in his patent that doing this not only resulted in data compression on the disc, that it also rearranged the data on the disc. It was a total joke and I'm told he had to go through several patent attorneys until he found one that was willing to even file for the patent, but he was granted the patent just the same.
se
se
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part II
