JLH 10 Watt class A amplifier
JLH69 said:
You don't need a PCB.
Just knock it up on some veroboard.
Then sit back and listen to an amazing amplifier, happy with the knowledge that you've saved an absolute fortune by not building a valve amp!
Maybe, but there is much more propensity to do things wrong compared with decent PCB's. Where the ground, rail decoupling etc is pretty much built in. I hear stories of oscillations with transistors which I have used with no problems etc. It must be appreciatted that when you get upto the MHz region/compensation - that layout and all that is a serious problem/issue.
Kevin
Kevin
Oh, I agree with you. However, I've built numerous JLH69s and JLH96s over the years and never had a problem.
I wanted to try to encourage Colin to get stuck in and not be afraid, that's all.
And to quote The Man Himself:-
Amplifier. The components necessary for a 10 + 10 watt stereo amplifier pair can be conveniently be assembled on a standard “Lektrokit” 4in x 4.75in s.r.b.p. pin board, as shown in the photographs, with the four power transistors mounted on external heat sinks........
Jonathan Bright said:
Greetings JLH69.
Yes I had a similar experience trying to chase up a more complete bibliography of his material for Geoff Moss's site. The obits indicated that he did some RF articles for a couple of Ham or Shortwave mags and they just didn't want to know about any sort of enquiry into his work. At least I got a reply saying that they weren't interested! Sad.
I noticed you said you had a lot of his articles. I've got all the WW (EW) and HF-NRR material and Geoff Moss has kindly sent me some of the ETI work. Is it possible for you to contact me (thru' diyaudio members email) as I would like to chase up a couple of ETI articles and get better photocopies of a couple of PCB layouts that have not reproduced themselves clearly enough to work from. (The local Assie ETI, now defunct, was very different to the UK product so public libraries here are no use.)
The other thing I have noticed in the last few days is the limited recognition he has got in the US. Nelson Pass and a few others are cognizant of his ideas on feedback and appreciate him. But I am ploughing through a large work on audio electronic mysteries that seems quite oblivious to JLH's contribution to the discussion of amp stabilty/feedback/sound quality.
Greetings to Southern UK. We left Bristol in 1957. Might get back there soon with retirement looming.
Yours, Jonathan Bright
I did email you, Mr. Bright, but haven't received a reply.
Did you receive my email?
Hi JLH 69
Yep thank you for the support
I just wanted the PCBs as this makes it a bit easier to build I could make the pcbs but its a bit of a hassle I should point out that this is the headphone version I an about to build same schematic just different resistor values mostly
Guys, your amps run at about 2A constant current yes? And the JLH96 one is at +/- 22V symmetrical, correct?
If so, it dawned on me that if running them from high current shunt regulators they may sound mega, and still run the shunts just a bit over, and they will not need very big heatsinks for themselves since the shunt current will be on the audio amp bias load all the time. Since the shunt Mosfet is working light enough, I guess that a common 1C/W sink for each shunt will do. You can also use 27-28V DC in for the regs and that cuts 5W dissipation from the CCS Mosfets, VS 30V reg in. You will not need humongous rectification filter capacitors due to the high ripple rejection of the shunt regs. Cuts costs a lot. The parts I put in are very easy to find and logically priced. The TO-247 case Mosfets are tough and need only an isolation pad and metal screw. Don't know, maybe you wanna give it a go. Such regs give an enormous subjective performance boost in my experience. You gotta be sure that your Led string drops 5.4V if you make it, because it can easily give much more current for small variation. Because also the Mosfet Vgs varies from part to part, check the voltage drop on R1 to derive the current. I would have 0.47R,0.56R on hand. The about 2.35A limit is a hard limit due to the CCSed regs. If your speakers need more ceiling you can up the current and sinks by making R1 smaller. The shunt CCS-IbiasJLH difference, is going to be burned on the shunt Mosfet times the Voltage across it if the program is not asking it, i.e. most of the time. So its no good practice if you don't really need it. Don't test them without 2A load current, that will mean 52W on the shunt Mosfet, and the small sink will not help it.
colin.hepburn2 said:
Hi JLH 69
PCBs are available from time-to-time ex-HongKong on that auction site. Indeed, along with kit sets.
Having had both a JLH and a SET amp in the house, I think you'll be happy with the result.
I've been meaning to try either choke input; shunt input or battery supply as the PS is the definite weak point of the '69
Hi thoglette
Thanks for the info on the pcbs gave you got a link to that auction site
In theory yes, in practice assuming the pot is set at 25 ohms that means firstly the adjustment would be super critical with the pot at one end... you could counter that by paralleling with say 68 ohm fixed resistor.
Secondly assuming a pot on it's own, the current in the wiper would be around 30 ma which is to high for a small pot.
Best solution, use a pot, get the adjustment right, then use a pair of fixed resistors instead.
