JL HD750/1 burned Power supply
So, PS is working fine. Removed Audio section, uncluding drive ics. Some fets where short.
Problem still is, that the amp is not switching of. If i remove remote, the amp still producing rail and pulls 0,5Amps... LED is off, when i remove remote..
Repaired PS completly, changed Audio part irs and mosfets.. I have Amplitude from the IRS to the mosfets... But no Audiosignal to the irs... Also the amp still dont switch off..
The LED is flashing red and green, but still produce rail, and also the audio part ist still working... But no audio
The pictures shows the pulses at the fets..
At the input of the drive ics, I have also pulses,
But no audio...
