JL Audio 750/1HD DC Offset
Here are the Pictures.
Rail builds Up,mute Switch Off,DCO Starts raising Up to 4V.
DCO goes slowly down again .
Remove remote, DCO Spikes Up again,and a microsecond later,mute switches on.
Amp powers Off completly.
Thats the Problem.
If you connect a 4.7k resistor and a 1N4148 diode in series and connect the striped end of the diode to the remote turn-on terminal and the resistor to the base of the transistor that's connected to R187. Does that switch the SD terminal quickly enough to stop the turn-off noise?
Does the amp pop with the 4v DCO?
If i connect the diode to ground, the subwoofer pulls down. DCO -8V. So, a Pop, but other direction.
If i remove the Remote, and connect the diode to ground, it does the same.
Because the amp needs a moment to completly shut down. Normal idle current 1.4 Amps, remove remote, current is 0.8Amps for about 8 seconds.
