JL Audio 500/1v2 Power Fets Burned
Well just a quick update, got the new gate resistors and the 3205's put in... Powered it up thru a fuse. The power light would pulse off every 5 seconds or so then my fuse blew about 20 seconds in. Didn't get a chance to measure any voltages. The heat sink on the power side warmed up a bit nothing smelled or felt hot after the fuse blew. Thinking I might pull the outputs and see if maybe they are bad after all. Also going to check the power side to see if they were damaged before the fuse blew
Had a few minutes this morning to take some measurements and it appears that the 4 fets nearest the rectifier diode are shorted. All the gate resistors still measure fine and the 4 fets to the other 4 fets further down in the group of 8 still measure fine. Any pointers on what I should focus on that would have cause 4 of the 8 to shortout?
Did all 4 of that groups short or only 1?
A defective driver transistor, a bad solder connection or a broken trace could cause the FETs to fail.
Did you have them tightly clamped to the heatsink with heatsink compound applied to both sides of the insulator?
What size fuse?
What power source when testing?
They had compound/insulators and were clamped. Power source was a car battery @ 12V, and the fuse was a 20amp... Lost my 10 amp fuse I had sitting around. All 4 in the group failed . When the amp was originally disassembled it was the other 4 that looked the worst. When these failed they didn't appear damaged unlike the originals that blew up explosively apparently
so, fets pulled there was one bad that caused them all to read shorted. I didn't see anything out of the ordinary with the solder when removing them. Should I replace the group of 4 or should they be ok for testing with the shorted one replaced?
I swapped out the group of 4 and probed around with the meter. I didn't find any solder bridges or open connection. Tried powering up again... Checked the voltage at the 3 leg on the driver transistors and it slowly climbs to about 3 volts them drops back to 0. The amp blows a 10 amp fuse after a few seconds. Is it possible for the diode to fail with out looking damaged?
Yeah, probably should have started with the obvious thing seems how the power fets were roasted and the outputs were fine... Checked the diode and one side is a dead short and the other is open... Any thoughts on anything else to check that could have failed because of the diode or it shorting and taking out the power supply pretty much the end of the line?
I've put about an hour worth of use on this amp and i've noticed the transistor just under the small transformer is pretty warm.
First I was wondering if that is fairly typical in this amp to have this transistor run warm?
Second it looks like there are some small led's on the main board. should any of these be illuminated during normal operation of this amp?
Y0ygpiN6xBE1LXpslDF4cNWVi_RF8qnpvTqSq9Il2w=s215-p-no
