JL Audio 1000/1
This amp has very low and distorted output..
Can barely hear the audio have to put ear next to speaker in order to hear it..
I tryed unpluging the preamp board and repluging it back in no difference..
On all the op-amps on the preamp board i get the following voltages on pins 4 and 8 of all of them ..
Pin 4:-8.15
Pin 8:5.15
Also noticed this..
Is this repairable or not really??
If so where do i start?
It appears that that resistor is being substituted for the one with the burned pads under it. If I'm not mistaken, U801 drives the two transistors to the right of your arrow. Those transistors drive the resistor which drives the transistor.
Does it appear that the FET has been replaced?
Do you see a clean square wave on the bases and the emitters of the two transistors?
Are you sure that the power supply isn't blown?
U804 is a pair of driver transistors that drive the driver transformer that drive the power supply FETs.
Apply remote and remove it. You should have regulated voltage for about 5 seconds. Does the regulated voltage on the op-amps go to ±15v in that 5 seconds?
