JL 500/1 component identification
JL 500/1 PCB 100005 Rev 10
Amp had low volume and muddy audio, then went out completely
RCA input read short. I need help identifying this part.
It’s in front of the supply capacitors
Thank you.
I changed diode and started checking voltages on 10 pin connector near +- inputs and got to pin 4 , then blew changed diode again and small pop sound emitted from test speaker . when pin 4 probed for voltage.
1. 5v
2. -14.9v
3. 13.7v
Low power input selected and gain set lowest position
I was praying it was muting component that I’ve read about in similar posts here. I still haven’t lifted it because my voltages weren’t similar enough
