Here is one of the last sets of FE127eN. These have EnABL2. You will note that they have the same spot colour as the FE126eN^2 above except that the mid-cone ring is also in colour. The 126 is the standard colour scheme, i have given all of the FE127 & old FE126 the coloured mid ring so as be able to more easily distinguish them in the filed. Coloured mid-rings on the new FE126eN^2 will appear only in custom colour drivers (which could be Natural w Brown as in the 127s below)
I have a couple even more daring ones in the works for auction to the benefit of the forum... the sonic requirements of the mods limit the possibilities somewhat, one of the 2 pair i will do where i haven't before. And for the other, i'm on my 2nd try, i tried a coupl things that would extend my reach and found some things that wouldn't work.
I saw your girl on the speaker... if that kind of thing could be done without compromise it would be cool.
dave
dave
prismacolor has a very vibrant light wax pencil, simple ink outlines look sweet for pinups as well.
a good method of transferring fine detailed drawings can made through image projections and or stencils or trace paper.
i see there could be a big market for artistically designed inducers, you have the means dave so keep it up!
personally i want my tube amp schematic printed on a set of cones, maybe i shall..? it will be long time before i can purchase any new speakers, though i found a blank white cone for re-conning , just need the right 15'' baskets now.
Wax wouldn't work, as the functional coatings are water based and the 1st one needs to bind the surface of the cone. At this point i am limited to the PVA (mod-podge) for the initial coat typically coloured with food colour (and limited to amounts of colour that bring the PVA to the same consistancy as using water to thin it). It is also necessary to keep the coating consistent over the whole cone.
dave
dave
See you monday!Hey Don,
Freshly finished copper Alpair10eN
Don
Something special. And something special will be done with these. Stay tuned.
Dave,
I'm not even British, but those are very cool indeed.
I just hope you restrain yourself from doing a pair with that Red Fig Leaf that I see everywhere.
Just kidding. But I "do" have an idea where those are going.
Best Regards,
TerryO
I have trouble enuff doing that Red "Fig" leaf on a flat piece of paper with a pencil & an eraser. I'd have to come up with a charicature. Flags with straight lines i'm not so frightened of now.
dave
dave
I have to say you really outdid yourself on this one! It will probably open a whole new market in the Commonwealth.
Best Regards,
Terry
- More Vendors...
- Planet 10 hifi
- It's not easy being green (apologies to Kermit)
