1) Pee Cee Bee V4 Two board plus 4 selected Mosfet 2x ECX10N20, 2x ECX10P20 (blue-yellow lot ). ALL 55 Euro
2) Amp 2 Modules P3A 40-60W P3A, 1 PSU pcb - Capacitors Nichicon 4.700uf/50V, MUR 860
Capacitors Nichicon 470uf/63V -Wima input caps 2.2 uf/63V X 2
Mica caps 100 pf-500V
Matched input transistors ON Semi, 550-560.
ΜPC71 Non-Inductive Resistors 0,22 R
Toshiba 2SC5359 - 2SA1987 original transistors from Elektor
Offset 1-3 mv 40khz tested under load 8Ω ..photo All 75 Euro
3) ES9018K2M DAC Isolated with ELNA for Audio ROA Cerafine 100uf/10V made in Japan with default opamp 5532 . 40 Euro
4)0.8uV Ultralow noise DAC power supply regulator +-12/15V, 1.A LT3042 DIYINHK SOLD
0.8uV Ultralow noise DAC power supply regulator 3.3/5/7V 1.5A* X 2 LT3042 DIYINHK 40 Euro SOLD Only one available .
5) PSU +3/5/7V 4ΧMUR 860, Μain Cap 10.000uf/35V Panasonic , Panasonic 1000uf/25V Low ESR, WIMA 0.22 uf MKP 40 Euro
6)Two OPA 627AU Double matched. 15 Euro SOLD Only one available .
7) Amanero Combo384 Module Original - USB class 2 to I2S 32bit and DSD output Adapter Black Color 45 Euro SOLD
All items for friends and family plus shiping cost.
The i/v stage is included?Yes it is on the socket, but it is sold separately.
One power supply regulator +3.3/5V, 1.A LT3042 DIYINHK SOLD. Only one available .
Amanero board SOLD
One OPA 627AU Double matched SOLD. Only one available .
1) Pee Cee Bee V4 two boards plus 4 selected Mosfet 2x ECX10N20, 2x ECX10P20 (blue-yellow lot ). ALL 55 Euro Available .
Offset 1-3 mv 40khz tested under load 8Ω ..photo All 75 Euro. Available.
3) ES9018K2M Isolated with ELNA for Audio ROA Cerafine 100uf/10V made in Japan with default opamp 5532 . 40 Euro. Availble.
4) PSU +3/5/7V 4ΧMUR 860, Μain Cap 10.000uf/35V Panasonic , Panasonic 1000uf/25V Low ESR, WIMA 0.22 uf MKP 40 Euro. Available.
See on first page the photos..
Amanero board SOLD
