1) Pee Cee Bee V4 Two board plus 4 selected Mosfet 2x ECX10N20, 2x ECX10P20 (blue-yellow lot ). ALL 55 Euro
2) Amp 2 Modules P3A 40-60W P3A, 1 PSU pcb - Capacitors Nichicon 4.700uf/50V, MUR 860
Capacitors Nichicon 470uf/63V -Wima input caps 2.2 uf/63V X 2
Mica caps 100 pf-500V
Matched input transistors ON Semi, 550-560.
ΜPC71 Non-Inductive Resistors 0,22 R
Toshiba 2SC5359 - 2SA1987 original transistors from Elektor
Offset 1-3 mv 40khz tested under load 8Ω ..photo All 75 Euro
3) ES9018K2M DAC Isolated with ELNA for Audio ROA Cerafine 100uf/10V made in Japan with default opamp 5532 . 40 Euro
4)0.8uV Ultralow noise DAC power supply regulator +-12/15V, 1.A LT3042 DIYINHK SOLD
0.8uV Ultralow noise DAC power supply regulator 3.3/5/7V 1.5A* X 2 LT3042 DIYINHK 40 Euro SOLD Only one available .
5) PSU +3/5/7V 4ΧMUR 860, Μain Cap 10.000uf/35V Panasonic , Panasonic 1000uf/25V Low ESR, WIMA 0.22 uf MKP 40 Euro
6)Two OPA 627AU Double matched. 15 Euro SOLD Only one available .
7) Amanero Combo384 Module Original - USB class 2 to I2S 32bit and DSD output Adapter Black Color 45 Euro SOLD
All items for friends and family plus shiping cost.
..plese tell me for this two amp modules and psu,on what schematics are this build,is this class A,class AB or B??
Im interested for this amp boards.
The i/v stage is included?Yes it is on the socket, but it is sold separately.
I'm interested in the +- 12v PSU
0.8uV Ultralow noise DAC power supply regulator +-12/15V, 1.A LT3042 DIYINHK 40 Euro
Shipping to Ireland....
Fran
Fran
One power supply regulator +3.3/5V, 1.A LT3042 DIYINHK SOLD. Only one available .
Amanero board SOLD
One OPA 627AU Double matched SOLD. Only one available .
1) Pee Cee Bee V4 two boards plus 4 selected Mosfet 2x ECX10N20, 2x ECX10P20 (blue-yellow lot ). ALL 55 Euro Available .
Offset 1-3 mv 40khz tested under load 8Ω ..photo All 75 Euro. Available.
3) ES9018K2M Isolated with ELNA for Audio ROA Cerafine 100uf/10V made in Japan with default opamp 5532 . 40 Euro. Availble.
4) PSU +3/5/7V 4ΧMUR 860, Μain Cap 10.000uf/35V Panasonic , Panasonic 1000uf/25V Low ESR, WIMA 0.22 uf MKP 40 Euro. Available.
See on first page the photos..
Amanero board SOLD
