Is this full wave rectifier correct?
I just tripped out my ps to track down the circuit but I am confused with the rectifier. The red lines is what it is. Are the white lines support to be? If it's wrong, why it works.
The board was top right and bottom green left and red lines are exactly as it. When I look at the schematic to trace down all the components then saw the diodes kinda weird. However, the amp is still working. Should I change to the white lines?
Another thing I found on the driver as well, cap and resistor reverse on the PCB and missing cap on the NFB. Omg, it was working great with a low end speakers until I hook up to the high end that was where hum noise start again. It's driving me nut So I decided to track down the whole circuit to compare with the schematic. So far that's what I have seen on the driver pcb. Still working to trace the whole PS pcb.
Please post a picture of the top of the Green board. So we can see the diode's orientation. They do not look like the same board in your pictures...
The 'bridge can be configured in two ways. See below.
The resistor / cap positions do not matter in that location. The NFB cap may not be necessary.
