Ok... So what's the worst that can happen if I just plug this chip in my board?
white smoke with black streaks criss-crossed and a slightly unpleasant odor.
previously measured the resistance of the pins
http://www.diyaudio.com/forums/digital-source/32587-real-tda1541a-post2645542.html#post2645542
Only way to find out it to try...
So I measured the pins... All open circuits... And tried.
No smoke, no explosions, no sound. In other words, a fake, but not damaging the pcb....
Dont buy it!
Dont buy it!
I am thinking a may have an authentic 97 A. As I understand these were fabbed in china and stamped in europe. This one has a german code HBH9751 2 and on the underside the circle indent is molded CHINA which I believe is an indication that it may be a real '97.
The only odd thing is a also recieved a HSH9414 and it has the same lot number 11226 as the 97, it doesn't have the CHina in the underside mold.
No continuity between any pins. The surface is from the mold, not sanded down.
Think the '97 is authentic?
Tazz, does yours have the china mold mark in on of the underside circles? (that I tried to take a picture of above) I can't see anything in that circle on your photo, can you confirm?
thanks
thanks
thanks
No it does not.
Any thoughts on this?
The date code suggests October 2004 were they still made then?
Seems the print is yellowish?? If so, then fake
Look a couple pages back... 2004 MAY BE genuine production... May...
Seems the print is yellowish??.
May just be the photo ..... its from a (UK) name that has been recommended on here 'little and diode together'.....but not sure its worth the risk?
This is what a genuine TDA1541A S1 Double Crown looks like.
This one is inside an unmodified Naim CD3 I have here. The machine is for sale for the right price 🙂
Are you sure? That 1541 looks rather fake to me. The 's1' is displaced and it looks like the font used for the 's1' writing is not correct.
Besides, i have never seen the 2 crows on a horizontal line...
This is my TDA1541A S1 double crown:
Philips TDA1541A S1 double crown d/a converter
Well, I just opened the box and there it is. The machine was bought new and has just come out of storage. The solder is perfect. Yes, I am sure.
I have read that all the best measuring S1s were given a crown, and only later these S1 were re-measured and the best of the best given the second crown, hence the slight change in crown printing. I guess then they started printing both crowns together like yours (unless yours is a fake 😉 )
Regardless, it's appearance in a very old and excellent Naim CD3 is a pretty good certification I am thinking. Normally they put single crowns in these machines, but I have heard of one other CD3 with a double crown. Pretty rare stuff, eh?
I quote somebody on this forum:
"S1 double crowns are S1 single crowns which have been re-tested at a later date and found to meet the S2 double crown specification. This explains why the second crown printing doesn't match the first one - the second crown was printed on a different machine."
I'll grant you though, it is most unusual. I cannot find another with this same printing on Google images.
I am guessing that Naim bought only from Phillips directly (and requested their best available chips - all S1 crowns usually) so we can say that this is not only a most excellent chip, but also very rare indeed, perhaps one of the earliest ever double crowns.
Here's a macro photo, which I'll admit may pose as many questions as it answers, but unless Naim were in the habit of buying fakes (did they even exist in the early 90's?) this is most certainly genuine and rare as hen's teeth, even before you consider the unusual printing.
Take a look on the picture on post #143 in this thread:
http://www.diyaudio.com/forums/digital-source/32587-real-tda1541a-15.html#post1903472
Same S1 with 2 crowns, and 100% sure that it is original.
Thanks Amauta! Great news. That's the first other pic of this kind I've found. If Franz Gysi of Studer has many NOS of these identical pieces, it proves it is genuine.
I'm guessing it's close to impossible to get my hands on a genuine single or double crown IC without spending a fortune?
Ebay sellers charge alot for them and then there's the considerable risk of the TDA's being re-labeled.
Looks like if you can find a real one you'll be well over $100USD. From what I've read and heard there is considerable risk of buying a fake.
Dan 🙂
- Digital Source
- Is this a real TDA1541A?
