@ b_force
You are right regarding "VAKUUM". We are talking about a maximum of 10 to 15 mbar measured pressure or negative pressure.
@Boden
If you're talking about Juergen T.'s solution, then it's certainly excellent, but I guess the price is probably in the region of €10,000-15,000 (just for the hardware).
Heinrich
@Boden
Heinrich
Yes you are absolutely right -That sounds good in theory, but if anyone who does all of these things deviates their designs away from the same ol' thing that Forum Expert™ narrative has dictated for the last 40 years, you will still get told you don't know what you are doing. I've had Experts™ on this forum call my designs "mud pumps" while the design is literally going into production as a high end hifi product, just because it's different than the thing they have known for the last 3 decades.
Only where cost to quality & cost of quality is a factor then-
To start - and get their business off the shelf and becoming a supplier (if only making the drive unit) or getting end product off the shelves into homes, most likely - Magnet size would not have been re-invented and off the shelf form would have been used (quality like Y28 to Y40 on N30 to N50 being a variable), as soon as the mag size is same - the top & bottom plates can be acquired that conforms to that shape easily from several suppliers. Depending country.
Once there is rolling - and if one had end to end control of the speaker parts - that is they make their own spiders & cones - along with vc & motor structure, - a lot of flexibility in trying new designs is possible.
Hi-End does not have costs to quality as a large limiting factor, with that said, small runs of Neo Mags is possible, thanks to the innovation & ingenuity that all the neo mags are sourced from that small runs of any form factor of neo-mags is available - else one would be yet limited to the 40 year old - 55,90,120,135,160,180 OD cer mags.
By the way - what is your design , did you make all the speaker parts in-house or they were bought from vendors.
Best Regards
Suranjan
Hi Mark - just a thought - cut the panels - dont glue them yet - buy cycle tube - cut into strips. Put these rubber strips between panels - then silicon - and screw.The more I thought about it, the more I have to agree. A few coats of polyurethane on the inside and outside you should be fine. Much easier to make a box too! The vacuum will be relatively small.
Hi, I hope it works out - all the best ! - May The Force Be With You in this journey.I am actually working on a open source alternative.
The easiest method to build a very airtight enclosure is to use a polyurethane construction adhesive. Sika is a trans-national company that sells this stuff all over the world. Here in Canada and the USA we have Henkel, and they sell a product called PL Premium. It is a reasonably strong adhesive. It expands upon curing so fills void s between the parts you are assembling. And is slightly pliable, not a rigid cure, so it is tough to tear apart. So enclosure made via the normal methods, glued and sealed and I need to buy a few air pumps. And figure out a little plumbing and wiring.Hi Mark - just a thought - cut the panels - dont glue them yet - buy cycle tube - cut into strips. Put these rubber strips between panels - then silicon - and screw.
Before that I have two Driver motor simulations I have promised to make and share. So much to do! So little time to do it!
That is a consideration, but isn't it sort of built into the typical spider-based suspension systems used in many low-frequency drivers? For PA-style drivers, the corrugated surround provides a similar effect, doesn't it?The suspension system should not be a simple spring as it needs to provide effective braking at x max.
Is that really the case? If the suspension of a loudspeaker was (significantly) nonlinear, over what would be regarded as being its "linear" operating range, would it not cause the driver to generate copious quantities of harmonic distortion? That would make it a failure as a loudspeaker, would it not?Therefore the suspension is not a linear spring with a mass attached to it
So, since we have many good examples of working and usable loudspeakers out there, an alternative assessment might be: depending on the design of the loudspeaker suspension system, it is an approximately linear spring, up to certain ±ve displacement levels, after which it can become significantly nonlinear in its behavior.
Exactly - and most of that you are addressing is bang on. The best suspension - is a suspension that isIs that really the case? If the suspension of a loudspeaker was (significantly) nonlinear, over what would be regarded as being its "linear" operating range, would it not cause the driver to generate copious quantities of harmonic distortion? That would make it a failure as a loudspeaker, would it not?
1: truly linear
2: with the ability to center the VC to avoid rubbing in ultra tight magnetic gap at extreme excursions
3. and only apply increasingly exponential braking force beyond - X Max / distortion limits case to case. (become non linear only at this point)
And this is why we are here trying - with the good people here - to make a DIY test system that we can use to test - Spiders and Cone surrounds that are able to do this. Without breaking the bank - for a Klippel measurement system.
I make the molds of the spiders and suspensions - that I have used in my own cones and tried all types of materials and material treatment - but to judge & find the correct suspension - we need the way to test the suspension non linearity and its effect.
I believe there is a system that B_Force is working on , and Kravencho is trying out the Dumax way ; keeping fingers crossed - and we are trying to get help and brainstorm as much as possible - to collectively find a solution. Any help is welcome.
- Subwoofers
- Is there a DIY technique to measure the BL curve of a woofer?
