Is it the end of class A/B (chipamps specifically)?
The tiny low power class D amps are beneficial both for conserving battery power and for conserving board space. Because the devices dissipate very little heat, they can be crammed into the tiniest nooks and crannies on the board, without causing thermal issues. So as soon as performance in a small package is required, those chips are the way to go.
I think smaller class AB chips will live on for a while, not only in EMI sensitive applications, but also in bottom-of-the-barrel products, where old technology is used to save cost and performance is not as important. Toys like walkie-talkies, megaphones and such might contain them for some more years.
Well I mean you're really talking opamp territory there. Or something similar.
Eventually there will be no amplifier IC's with analog inputs. It will be only digital in...
I would be surprised if this was the case. Class D amplifiers are, at their heart, analogue. Analogue in analogue out. The storage media of today might be digital but there are loads of ways and implementations for the D/A process. Either separate DACs, DACs built into a SoC etc, but all need amplification for driving loudspeakers. From a price point of view, it's a lot cheaper to use the in-built DAC of a Bluetooth communications device, and then pair it with a separate analgue in class D amp, than it is to use a separate digital in class D amplifier.
Sound quality is usually worse but the end product is simpler, more efficient and less expensive.
Of course there are some SoCs that don't contain a DAC to which a digital input class D amp makes sense. Some of these are essentially a DAC and analogue class D amplifier on a single chip.
I showed with Sublimed TPA3116D2 how it is possible to get as high quality as SE direct driven 300b. TI has recently developed a new 2.1Mhz technology along with Pure Path, The PCB with the output filters measures 17×16 mm only for TPA6304. In near future , applied for higher power units , will extinct the last watts off the chip amplifiers.
Certainly 1W output power and less.
The bargain bin and toy department is where old designs are recycled over and over again, so I don't expect any circuit innovation there unless absolutely necessary. A couple of years ago my son got a cheap set of walkie-talkies, of which the package proudly said "6 transistors". Now go figure how old that design must be...
For high quality audio, any class D scheme that is continuously oscillating (i.e. all of them at the time) is the switchmode equivalent of a class A amplifier and exhibits no crossover distortion typically associated with conventional output stages. To top that off, a switching element coupled with a decent inductor is vastly more linear than any active component could ever wish to be. Class D designs can and do outperform the best class A out there.
You may be right , but fact is that audio is a bit more complex than a pile of nice numbers , remember , there is an human brain in the middle of the experience 😉
but it's also a fact that somebody like it different just because it is different or new , fortunately we have the choice , which doesn't mean we are all able to make it without our cognitive bias
what ever happens , the simplest the better , always and for everything , even if some people like , really like , to make it complicated 🙄
My impression:
Short term, new class D chips will appear but existing class AB chip-amps will still be available. Development costs have been paid and chip-amps still provide a cheap and reliable solution to many uses.
For ordinary car radios, ST still has a huge range of BTL class AB chip-amps. In cars, audio power efficiency is not of importance and these chip-amps have a proven reliability. As said by Abraxalito, below 1W class AB will remain.
Class D uses switch mode techniques, as we all know, and switch mode techniques were developed for power conversion. For higher power levels, audio amplifiers use switch mode techniques in order to reduce heating so more compact and elegant constructions can be made.
Long term, switch mode techniques will remain for power conversion but my guess is that most future audio listening will use sophisticated ear-pods and low-power class A/AB electronic amplifier designs. SmartPhones and ear-pods may already today be the most frequent way of listening to music.
There is an irrational element in using apparatuses that can supply 2x 25W-500W for generating a sound level in bulky speakers that only requires mW in ear-pods. All we get out of the 2x 25W-500W is that we force our surroundings to listen to the same sound though they may prefer to listen to something else. My youth was with BIG speaker constructions. My impression is that speakers sold today are getting smaller and smaller because consumers in general do not accept to use so much space for huge speakers. Our needs for mobility and reduced ability to pay for huge accommodations will also favor compact low-power gear. Thus, my guess is that in the far future most will be low-power class A/AB and sophisticated ear-pods.
As more have already stated before me, audiophiles are a very atypical market segment with very different priorities.
do we care ? A good chip is a black box with manufacturer implementation ap. note and if it’s better than yesteryears black box the technology inside is of no consequence. Perhaps by knowing the technology inside you end up making the wrong choice due to your own prejudices or worse, reading BS spewed by others on the web.
I don’t think the demise of older chips should be any bad thing except for repair.
If you like to design and build your own circuits without black boxes, then all the details are relevant. We can build any Class of amp that takes our interest. It’s just DIY.
I have to agree with you on this one. A chip amp is a chip amp regardless of the amplifier class- the process of designing with one isn't too different.
As for larger class AB amplifiers, I don't expect them to be entirely gone for a long time. This kind of thing takes a long time to die out. They are already gone from live sound, with the exception of a few offerings from MC^2 (which is an expensive option anyways).
The advantages of Class D start to become smaller and smaller in a HiFi setting where efficiency isn't as big of a deal. The main killer of class AB in live sound, the massive weight, tends to be more of a selling feature for the home stereo market.
Added to that, the transistors used for class AB amplifiers have other uses. We may have to move towards SMD, but many people will argue that with a little practice SMD soldering is easier anyways. The equipment to do it is no longer outlandishly expensive. Quite honestly, I'd probably prefer to deal with SMD soldering than trying to desolder plated through-holes.
So really, aside from the issue of repair, I think that we mostly will just have to adapt. Our physical construction of amplifiers may have to be altered slightly, however, this need not be a bad thing.
Yes, the way mainstream users listen to music has pretty much gone to bluetooth speakers and earbuds. That said, traditional bookshelf and floor-standing speakers will not be going away any time soon.
.....Yes, the way mainstream users listen to music has pretty much gone to bluetooth speakers and earbuds. That said, traditional bookshelf and floor-standing speakers will not be going away any time soon.
My neighbors - mid-late 40's types, have "bought into" the "new" style of sound.
WIFI speakers, portable, etc... with internet streaming music.
I'm sure they're satisfied with that crap.
But when the husband came over, and heard my "all tube" 1963 RCA Victor console - he was totally floored by it, stating "Wow, that's the richest sound I ever heard!"
You can't beat a pair of 12 inch woofers with earbuds.
Honestly, Class A will always be a niche for those brave enough to put up with it. Still, I think it can sound great if it is well implemented.
There's no "right" way to do this. It depends so much on the application, personal preferences, etc.
While I tend to be a very practical person, mark my words I will design and build a 400 WPC liquid-cooled class A amplifier some day. Yes, I do know how completely ridiculous such a thing is, and I do know how massive of a project it will be. Some people put 1000 horsepower engines in their Chevy trucks, others build really stupid amplifiers. But hey, at least a big push-pull class A amplifier will probably be more efficient than said truck.
