Hi moamps
Thats very useful thank you.
I see you are creating 2 virtual ground one for the opamp cicuit and one for the transistor, why is this done. Also can i have a high res version, i am looking at yours to work out what the bright switch, tone pots and volume controls and grounded too. It looks like ground but surely its is to the virtual ground?
Please ignore the above post the language used is woeful, what i meant to say is:-
Hi moamps
I see you are creating 2 virtual ground one for the opamp cicuit and one for the transistor, why is this done. Also can i have a high res version, i am looking at yours to work out what the bright switch, tone pots and volume controls are grounded to. It looks like ground but surely its is to the virtual ground?
Sorry i was too tired when i posted,
phil
Hi moamps
phil
Hi Phil!
Nothing much changes in the redesigned version except that the non-inverted input of both op-amps and the base of the output transistor are now biased to 12V.
Re virtual grounds: There are quite a few ways to skin the virtual ground. 🙂 This just happens to be my method of choice. Lots of useful info on the issue of virtual grounds can be found in the Texas Instrument Application Report SLOA 058 (downloadable).
Re grounding: All ground connections from the original split supply circuit are preserved in my version as well (meaning that all ground connections go to the minus pin/pole of the bottom SLA battery).
If you'd like me to draw the wiring of the pots for you (in a high-resolution format), please send me a PM.
Milan
Milan
Hi Moamps,
Can i get that pot wiring diagram, i have been looking at your layout for a while and i think i understand how to wire up the tone pots onto those 5 headers but gain pot is a mystery since it doesn't seem to join part of the feedback loop like on the original.
Any help very much appreciated,
Phil
Phil
