Is GlassWare still functional?
Yes, I’ve emailed a question to him - about 2 weeks ago and again today. No reply to the earlier inquiry. About to move on also if no reply to the second email.
Difficult to place an order for items not in stock - or in the case of the Noval Stereo pcb Available on the site but then not in stock as you attempt to add to cart.
It still works for me, and I have placed it into my cart as available.
See the attachment below. Maybe try a different computer.
Is this the "error" you get:
  • The Aikido Noval Stereo Resistors for Aikido PCB with many redundant values : None 10 LV & HV Supporting Capacitors : None Set of Ceramic PCB-Mount Tube Sockets : None Cornell Dubilier 942C polypropylene 1uF 1kVdc Coupling Capacitors : None Cornell Dubilier 942C polypropylene 0.1uF 1kVdc Coupling Capacitors : None Cornell Dubilier 942C polypropylene 0.01uF 1kVdc Coupling Capacitors : None Sets of six PCB stand-offs and screws and o-rings : None Stereo-Freq switch & PCB for switching between output Capacitors and mute : None Selector switch & PCB for switching between 3 input sources : None Super strong double sided tape to hold coupling capacitors in place : None is not currently available. Please contact us for availability of this item.
The only preamp boards I can add with no hiccups are the SRPP+ Noval.
I put "error" in quotes as I was (and still am) drawing a blank on what else to call it.
At the end of the message is the statement:
No matter what combination of options I choose for the Aikido Noval boards, I get the same non-availability message. Can't even add Aikido Noval blank boards to the cart. Only noval boards that I can add are the SRPP+ boards, the same as you show.
@TroutBear , you trying to add the Aikido Noval and getting that message?
Reactions: emuffler
I'm curious too, as to the state of Glass-ware and hope that Mr. Broskie is doing ok. Been watching the store as I've been hoping the Aikido 12V boards come back in stock. An awesome tube circuit that is easy to implement.
I tried to order a power supply kit twice. The first time I heard nothing. The second time, I thought the order went through, but when I checked a few days later it said "the order has been canceled." I tried e-mail but got no response. I gave up and built my own. This was in October.
There was a Halloween Tube Cad Journal post on October 29.
Probably we will find out what's going on next week after the holidays.
Maybe just some time off. I've seen other small businesses set their inventories
to zero to prevent orders piling up, while dealing with other problems.
Yeah, I wonder if he's waiting on boards to be fab'ed.
Makes me nervous, when stuff isn't getting re-stocked. Seen so many vendors that make this hobby possible go under or retire. One of these days, I need to learn how to get boards fab'ed and start giving more to keeping this community going.
Yes - that message and the last lines stating not available. A Mac and Windows PC both the same.
