Look up the tubes datasheet and look at the maximum ratings for the heater, if its over or below that you might want to take action.
Lazy way to fix it is to use a resistor in series with the heater for some voltage drop.
No.
0.4V is less than 10%
Yes, but with typical line voltage variations, it could be up to +20%.
Too true.
I have seen discussions of some hi-fiers installing in-line UPS to rid their audio systems from the plague of noise and interference that somehow sneaks through. That system would keep heater voltage under control! Or alternatively use a motorised dimmerstat/variac with heater voltage feedback control
Is it 6.7V without load on the secondary of a power transformer, or DC after a solid state voltage regulator?
Possibly. If the voltage in question was applied to the filament inside a DF96, then clearly!Is a question without context a cause for concern?
No.
The 10% figure is always what I ran by as well. However isn't it mostly the current that we're worried about with the heaters? P,diss more specifically. I mean that's kind of the M.O. of the tube anyway usually, correct?
Saw a chart linked a short while ago on this forum about heater life vs heater voltage. Higher voltage shortens tube life. But a 10 % drop extends it quite remarkably. I guess too low a heater voltage is also bad for the tube . Keeping it at the correct voltage or within 10% lower at normal operating conditions is probably best. If it's a dc heater voltage you can easily keep it at a constant safe voltage.
- Tubes / Valves
- Is a heater voltage of 6.7 cause for concern?
