No.
0.4V is less than 10%
Yes, but with typical line voltage variations, it could be up to +20%.
Too true.
I have seen discussions of some hi-fiers installing in-line UPS to rid their audio systems from the plague of noise and interference that somehow sneaks through. That system would keep heater voltage under control! Or alternatively use a motorised dimmerstat/variac with heater voltage feedback control
Possibly. If the voltage in question was applied to the filament inside a DF96, then clearly!Is a question without context a cause for concern?
No.
The 10% figure is always what I ran by as well. However isn't it mostly the current that we're worried about with the heaters? P,diss more specifically. I mean that's kind of the M.O. of the tube anyway usually, correct?
Saw a chart linked a short while ago on this forum about heater life vs heater voltage. Higher voltage shortens tube life. But a 10 % drop extends it quite remarkably. I guess too low a heater voltage is also bad for the tube . Keeping it at the correct voltage or within 10% lower at normal operating conditions is probably best. If it's a dc heater voltage you can easily keep it at a constant safe voltage.
- Tubes / Valves
- Is a heater voltage of 6.7 cause for concern?
