A differential input uses two inputs to produce a single waveform. The simplest way to get a differential input is to use a differential probe. A differential probe has two signal leads and a mixer amplifier built into it. It feeds the scope a normal signal (a composite of the two signals input into the differential probe). The problem with differential probes is that they're expensive. The cheapest ones are about $60 used and they can cost more than $3000.
The alternative is to use two scope probes and and both inputs of your oscilloscope. This is how you have to set up your scope:
Two probes
Both scope inputs used
Input set to add
Both channels set to DC coupling
Both vertical amps set to the same voltage
Ch2 input set to invert
Bandwidth limited (works best for most measurements in car amps)
Trace aligned to the reference line on the scope's display
Ground leads for both probes connected together
After setting up the scope, you need to confirm that it's working as it should. With the vertical amp set to 5v/div, touching the probe that's connected to Ch1 to the positive terminal of your 12v power supply should make the trace deflect about 2.5 divisions up from the reference (like it always does, seen below). Doing the same with the probe connected to Ch2 should make the trace deflect down about 2.5 divisions. Touching both probes to the positive terminal of the 12v power supply should cause no deflection. If it does, something isn't right.
Two probes
Input set to add
ok Perry i will check these,all these,and i will let you know....thank you so much....in a few hours i will replay....thanks
If you touch both probes to the 12v terminal of your power supply, where does the trace move to on the display?
That's not how it's used. Differential mode turns the scope into an isolated scope where you use two probes on the same component to measure things like the drive signal. This gives far better resolution for signals that are referenced to the rails.
Take both probes and touch them to the drain/tab of a single PS FET. Post a photo of what you get.
You should have only one trace showing, not two. You missed a setting somewhere. Probably the 'add' setting.
- General Interest
- Car Audio
- irs21844s help..
