irs2092 and different temperature of mosfet
how can I verify that it is the dead time? I have removed the r26 but the mosfet always remains at a temperature more than double the other.
Although tonight he played for 2 hours at very high volumes. only that the coil gets too hot. 50 degrees despite the fan.
I think there is something that the face warm. the same amp mounted in a chassy does not heat up so much time, it stops at 43 degrees max. cards purchased in the past instead of the coil heats up a lot.
for the dead time if the port pin to B-(-78V dc, it's ok?) should I set it to a minimum, right?
