irs2092 and different temperature of mosfet
Since some card has burned out I wanted to check the temperatures of various points. I noticed a strange thing: why the temperature of the two MOSFETs is very different? a mosfet to about 110 degrees and the other body to about 35 degrees.
The coil gets to about 45 degrees with all the power from 50 0 50.
The mosfets are 4227 Monto irfb23n20d while if the temperature rises to 110 degrees while the other one remains at 35 degrees.
10k +10k for dead time.
I did try to use the same values ​​of 3.3 + 8.2 datasheet but the temperature does not change. reducing the resistance of the PWM frequency the temperature drops a lot. of defual there are two capacitors from 1000nF and the resistor 360. putting a resistor 170 the temperature from 110-120 drops to 80. with 120 ohms the temperature drops to 60-70 (the other mosfet always 30)
forgive the ignorance. gate driver you mean a dedicated chip? I have not. the schematic is similar all'iraudamp 7.
the supplier does not want to give me the schematic.
For iraudamp7 you need something like irfb4019 mosfets with low gate capacitance.
If you are using irfb4227 then the 2092 isn't powerful enough to drive them.
With irfb4227 you need npn/pnp buffer or a tc4420 buffer.
The 4227 has a high gate capacitance.
