Iron Schmitt phase inverter - lowest THD seen
45,
and Dorin Bodea,
Tacoma Narrows bridge (the original one, not the working pair we have now).
Versus:
The aging and working San Francisco Golden Gate Bridge (which went up in the same decade as the original Tacoma Narrows Bridge).
"All engineering solutions are equal, but some engineering solutions are more equal than others." - Me
Stolen and modified, with respectful reference to George Orwell's "Animal Farm".
Of course there are influences on engineering, coming from marketing, bean counters, and city mayors, etc.
Never let it be said that engineers are always the cause of a failed engineering project.
I do enjoy reading and analyzing both of your many posts.
Thanks!
can't help miself posting these gems issued about 5 years ago here, on this very website 🙂
@Pyka - sorry, I haven't visited this thread lately... I don't remember the exact operating point but was nothing unusual...
@Svytoslav - together with a good friend we've successfully simulated about 3-4 output stages using different SS devices, although I see more merits on keeping the amplifier all-tube. In all these simulations I've used ECC81/12AT7 tube class because I doubt a SS device will give better linearity - for more on this later
Meanwhile I've sourced several batches of cores and also some specialty magnet wires to advance in this project, stay tuned!
Two further options; the two 32Ohm coils inserted at the CT to both lengthen the primary, and give two more accessible taps across the primary. Or...use the two of them for a screen FBK winding so g2 can run at a lower voltage( perhaps TV sweeps?).
Douglas
- Douglas - first option you mentioned modifies of course the overall impedance (increasing the transformation factor too) and also moves the 33% ultraliniar tap up or down, depending where you insert these windings (2, 13 or 4, 11)
The second option I find it more useful, especially for those TV sweep tubes with huge voltage difference between Anode and G2 - yes, you can have a "safer" ultralinear connection this way. Thanks!
