Hi N-Channel,
Thanks for the reply...I frankly say to you that I'm not used to toroid specification or the type material of it before and even now..I just bought them for the reason that I know some SMPS circuits also use toroid as main transfo...But surely I already tried it and as you said it worked too but I noticed its limited power.. maybe due to its size..
outside diameter is 3.5 cm
inside diameter is 2.5
thickness is 1.5 cm
What do you think is its max power?
thickness is 1.5 cm
