Looks like a few folks in the U.S. have already received their boards. I hope to receive mine soon!
Best,
Anand.
Best,
Anand.
Any sets remaining? I can pay immediately, I just need one set for myself
I also need a set of M2X boards (plus daughter boards) but that may be outside the scope of asking on this particular thread.
TIA
TIA
Just a quick reminder that any and every diyAudio member can order IPS6 and/or IPS7 PCBs directly from a PCB fab, and have them shipped straight to your house in your country. It's fun, it's easy, it's inexpensive. And it's also the next step up in maturity as a diyAudio builder.
(link to #4371)
The manufacturing CAD files ("Gerbers") are freely available for download. They are attached to M2x post #3408.
(link to #4371)
Thank you for the link Mark.
I have done that in the past for other projects and would happily do so again if I can get my hands on the M2X PCBs.
I'm not sure about this but I'm thinking about fitting this IPS7 buffer in front of my F6 to replace the k170/j74 jfets and wondered if it's possible or advisable to arrange this to obtain an extra 6dB gain so that a typical 2 volt signal (ie CD player, DAC, etc) will produce full F6 output - at present, it needs about a 3.5v signal.
Could someone add some info about this, please ...
Mouser is running out of KSA1220AYS. What are the most important specs (other than the pin out) that I should look for to substitute the KSA1220AYS/KSC2690AYS?
- Group Buys
- IPS6 and IPS7 ( for M2x)
