Interesting amp in Pass Gallery
It looks like he used U-channel aluminum which is what I am planning on using for my Aleph 5. I am planning on constructing the amplifier vertically and mounting it on a plinth, a bit like the monolith from 2001.
The U-channel is readily available from the likes of Home Depot and Revy, it is available in 18mm, 25mm and 37mm. I was thinking of using the 37mm.
Tony D.
Hello Tony, it is far too expensive for this type of work, it is good for finish work, but if it is not going to show pick it up at Metal Supermarkets.
http://www.metalsupermarkets.com
This is my A75 Chassis
Hi Coulomb,
Thanks for the link.
I was lucky to find 30 metres of the 37mm U-channel at 50% off. It is not in perfect condition but good enough for my purposes.
Good looking A75!
Did you buy your heat sinks from MetalSupermarkets.com and if so which product are they?
Cheers.
Tony D.
That's similar to the way i'm rebuilding my JLH now. I'm using 6mts of an Al extrusion that's been cut in 22 pieces which will be bolted to a Cu sheet to form the 4 "sides" of the box. The extrusion itself (http://www.sannellaaluminio.com.ar/planos/xvarios/1804.gif) was arround $4-$5 us dollars, and after drilling and doing some sanding and leveling i'll have it all black anodized.
All in all, the finished amp will be quite small (180x180x220 tall), but if it performs as expected it wont rise more than 30-40°C over ambient. It's quite a lot of tedious work, but if done well it will perform very good at a VERY modest price.
Very nice design, Coulomb. Rather elegantly proportioned. Kind of looks like an Pass Labs Aleph on steroids! Or, "stacked Alephs"!
You must have a lathe, because it looks like the feet are turned down a bit to a soft point. My A-75 (which is built but does not yet work) is in the old conventional style with sinks on the sides and a big ole' rectangular plate on the front. I like to see things like yours that push the mechanical design envelope. Especially when the result, like yours, has a hint of understatement about it. The radius'd corners on the top and bottom plate are a nice touch.
Did you do a thermal calculation exercise for this or just say "we don't need no stinking calculations" and throw aluminum at it? I took the latter approach, but that's because I found humongous sinks on some surplus RF equipment for $20 US each (flat backs mated through polished surfaces to 5/8 inch thick aluminum plates.) and figured (looking at some other folks' examples) "this just has to be enough sink". Next time I want to go to the Aavid page on how to do the calc's and try that.
By the way. I found this Aavid thermal interface material in a stick. Its like wax, with better thermal transfer coeff. than that nightmarish grease. It is in DigiKey's catalog and is very easy to apply. Unlike the grease, it doesn't bleed, and cleans up easily.
Thanks Guys, I am proud of it. I admit my calculations were based on Aluminum mass calculations as opposed to surface area.
Part number please. 🙂
Anthony
Yes, I too was looking at those "car amp" heatsinks on Queen, but I didn't think the fins were deep enough to be of any use for a class A amp. How does it work for your amp? Cool enough? Did you get them in bare aluminium or did you strip the finish off?
RonS
I have not run a Class A Amp on them yet, but my 300 Watt AB Amp runs quite coll on two of them. See Picture below.
Active surplus only has one more, I bought everything he had including his warehouse stock. I purchased the bare aluminum ones as the black ones are 20% smaller and are predrilled not blank.
There is definitely sufficient area in my design for a Class A 75 Watt Amp. I will post a follow up when it is running.
Anthony
I have two kinds of boards. One is double sided, only front end and Fets mount on chassis as here http://www.diyaudio.com/forums/showthread.php?s=&threadid=3353 . I'm asking $100 CAD for those.
Then I have another set of boards with regulated power supplies included (copied from Mark Levinson 23.5) and layout based on original article. One sided, heatsinks on Fets and Holco resistors. You would need about 2x50V AC for PS. I would be asking a bit more for those boards.😉 Those boards are tested and guaranteed to work OK.
